Chris NottMonster Motorsport
Results 1 to 28 of 28
Like Tree1Likes
  • 1 Post By Westy
Thread: Forge actuator.....
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Forge actuator.....
    This has been covered a few times i know, but.
    Ive been offered a nearly new forge actuator for £60 delivered, which is well under half the retail price, now ive heard mixed reviews on them, are they really that bad?
    Also, my cars 12 years old and on 120k miles now so i suspect the old actuator will be abit past its sell by date.
    Whats your views lads?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    They suffer from very little travel, stick when hot producing boost spikes and iffy boost control and the diaphragms can leak... I have seen some with a newer design that 'look' better in some aspects but still retain the plastic bush (that sticks) and travel doesn't appear to have improved but I have not really used a new one yet so could not comment if they are any better...
    The Forge ones tend to suit bigger turbo/high boost setups (like Wellys for example) where control can be a little of a concern..
    As a replacement for a std 0.5bar actuator on a std turbo I would personally prefer to fit an OEM style one...
    Be wary of the spring rating if you do buy one... they tend to come with non std springs... which will give you a few issues on an un mapped engine..
    <tuffty/>
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So would you say its best to just leave alone PT? It would be going on my stage 2 unmapped s3, i know it needs mapping haha.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Forge actuator.....
    Surely it's not stage 2 till its been mapped?!
    ShaunS3 likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Stage 2 equipped my friend, and then some , just minus the map haha.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    symptoms,danni?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What do you mean symptoms mate?
    Aug 2012
    Nr Bath
    12
    Sorry, not looking to take over the thread, just a quick question as i'm new to these engines. How hard is it to change the actuator? As mine already had the forge one fitted when I bought the car, its only recently after reading some of the threads it seems i will be wanting to put a std one on. Thanks
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Quite easy to do as i recall. I had one fitted when i got the car too & had to take it off to replace the diaphragm.
    Not a big job.
    ...... Now this one's MUCH better!...
    RIP S3dave
    May 2004
    nr Glos
    7,175
    just cos its forge actuator does'nt confirm its spec. they are available with different spring rates, so remembering your stock actuator and ecu is designed around 5psi opening, bare this in mind when choosing the spring rate you want to run.... mapping vs a significantly higher psi actuator may lead to large boost excursions... aka spike like a mofo... so check with your choice of mapper before adding it if I were you
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,764
    Dan
    Why all the changes yet no map?
    Replace an actuator ( or adjust it ) when the map/vag com shows the car isnt making/holding requested boost.
    As PT said... best left alone
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I just havent got around to it mate and i know the clutch will pop as well, 120k and no proof of changing somits due out soon lol, also im happy at the minute with how fast it is, puts r32's, st's etc to shame so itll do until the clutch is changed.
    S3 Paul's Avatar
    Oct 2006
    2,764
    Whats the "stage 2 +" level of kit?
    Personaly i would want it mapping to avoid any of the new bits making the car run close to or over the limits of the map.
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    V2 b5 intake, jetex cone filter, welly cooler with 63 and 76mm pipework, 3" dp with 3" tbe decatted, ported inlet manifold with v6 tb, custome dv relocation with mad max dv, phenolic inlet gasket and forge non res hard pile, ooh and aome 2.0t coilpacks.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    And a few other littlw bits and pieces but their the major mods
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    If anyone is interested,I called up ce turbos today.they sell a OEM apex actuator for 90 delivered
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Reesy's Avatar
    East Sussex
    3,604
    I don't understand why the car is not mapped?!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Just havent got around to it and like said i havet got the reddies for the clutch as i know once mapped it will just slip as the car looks to be on the standard clutch at 120k.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Quote Originally Posted by Paradox1 View Post
    you mean CR turbo's? I need a new actuator. Mine is rubbish. But people do say the forge one is good. I can't see that when the bush is plastic!
    RIP S3dave
    May 2004
    nr Glos
    7,175
    they do metal bush also - ask for one
    www.badger5.biz
    bill@badger5.co.uk
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Will it still be too harsh for my tiny k04? If so, rather go for a OEM one but can't find one anywhere!
    RIP S3dave
    May 2004
    nr Glos
    7,175
    what do you mean harsh??
    www.badger5.biz
    bill@badger5.co.uk
    beachbuggy's Avatar
    Surrey
    1,745
    Which bit is the bush in these things? Not seen a forge one, so assume the plastic bit melt?
    RIP S3dave
    May 2004
    nr Glos
    7,175
    the outlet bush where the rod goes thru is blue nylon type material.... and can melt.. We all know how hot k04s run.. and this bush sits in direct line of fire..
    i have melted these before, which seizes the rod up completely.. They have supplied phosphor bronze equivalents before when required. thats the ones I would opt for personally.
    www.badger5.biz
    bill@badger5.co.uk
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Oh I read that it can make your car produce boost spikes because of the spring Etc. must of read wrong. Ok I'll order one with a metal bush and yellow spring? Can you get these bill? If so ill add it to my shopping list after Xmas after brakes and intercooler welding lol.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by Gops View Post
    depends on the spring and mapping whether it will spike..
    If you stick a stiffer than oe spring in it and dont chnage map then yea I would expect it to spike boost, but thats not because of the forge actuator per say, but because the actuator is set at a higher pressure..
    I can get them yes.. It should be fitted and mapped to suit.. Important if going for stiffer spring rate *(which would be the only reason to change this anyhows)
    www.badger5.biz
    bill@badger5.co.uk
  28. #27
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,637
    Your a G, Badger B! (My legendary rapping!) I'm gonna fit it when I do a stage 2 so the map can accommodate for the new actuator. What spring would you say is good for stage 2? And before you ask about my tfsi build, I've had to push it back for a few reasons and I didn't want to live without abit more power so this is my compromise lol. It will be done though..
  29. #28
    RIP S3dave
    May 2004
    nr Glos
    7,175
    I would aim for 9-12psi crack pressure region
    www.badger5.biz
    bill@badger5.co.uk
  1. Forge actuator brand new to fit 2.0tfsi
    By nil538 in forum For Sale/Wanted - Audi Parts
    Last Post: 22nd April 2012, 18:51
  2. FORGE MOTORSPORT ACTUATOR TT/S3 FMACVAG01
    By s3bpm in forum For Sale/Wanted - Audi Parts
    Last Post: 22nd October 2011, 10:02
  3. Wastegate actuator
    By Steve1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2003, 23:38
