Badger5Monster Motorsport
    Erf
    Oct 2006
    Kingston
    234
    Routing mic cable for handsfree
    Guys,
    Might be being thick here, but I want to route my mic cable along the red line I've drawn in the pciture. I can tuck the cable neatly under the rubber channel by the window, but how or where do I tuck the cable around the pillar and up along the window screen??
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    The a pillar trim just clicks off mate. Or you can tuck it behind the edge of you don't want to take it off
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    PaulRS3's Avatar
    UK
    1,005
    On my previous S3, i fitted a SE Bluetooth kit. I mounted the mic in the oem position in the central light cluster.
    Having removed the central light, and "fished" the cable over the the roof lining and down the drivers pillar, (without removing it, I managed to tuc it in with a credit card)
    Audi RS3
    Erf
    Oct 2006
    Kingston
    234
    G60leigh - I have a curtain airbag so not sure I can just prise off the a pillar trim, or can I....?!
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    You don't need to prise off the trim, just pull the door rubber back and slide it behind the trim that way, much less hassle. The door rubber comes off so easily and just pushes back on - don't bother pulling trim off unless you really have to.
    I did this to install my Parrot HF and it was the same on my 8P S3 too.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Erf
    Oct 2006
    Kingston
    234
    Cheers beanoir. Will give it a go!
  1. Vag-com Cable for 2003 S3 - Will this work?
    By [Dave B] in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th January 2007, 15:59
  2. ODB2 USb cable for A3(8P)
    By MrLapou in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th September 2006, 07:21
  3. Vag cable for Golf - will it work in the S3?
    By jazz_2004 in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th February 2005, 23:31
  4. Best for running power cable for amp in a3
    By bigshout in forum In-Car Entertainment
    Last Post: 19th December 2004, 21:19
