JMB RetrofitsBadger5
Results 1 to 7 of 7
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    BILSTEIN B16 PSS9
    Hey guys, anyone fitted these from AMD? BILSTEIN B16 PSS9, any advice as to how good they are? or not? Cheers [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    sssgucci's Avatar
    Oct 2004
    UK
    98
    Re: BILSTEIN B16 PSS9
    Bilsteins are really good. Not sure if this model is the coilover kit but if it is thens its should be a great kit.
    However if you want to spend less, then check out my trading post advert! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    I can supply other makes too.
    ELIASGK74's Avatar
    Mar 2004
    greece
    47
    many friends of me have tried pss9 and then change back springs with H&R ones because of problems(check back spring libres of pss9).
    Also after one year pss9 suspension is very hard even in level 9.
    I am looking for KW varient 3(the only one you can change rebound)
    Defratos's Avatar
    May 2004
    2,230
    Not sure if the KW would be better? it's not track tested as the Bilstein B16 PSS9, and they are fully adjustable, and as far as my research shows u can change the rebound.
    JaminBen's Avatar
    Jan 2005
    France (ronRonrRRron)
    532
    Well, the PSS9's single adjustment knob affects both compression and rebound curves.
    KW's Variant 3 has two adjusters, to affect compression and rebound independantly. Sounds like a tuning nightmare to me.
    ELIAS S3, I would love to know more about your friends' disheartening with the PSS9s. What were the issues? Thanks in advance.
    sssgucci's Avatar
    Oct 2004
    UK
    98
    KW corrode after a year. Good freind of mine had these on his VW, you need to keep the thread well lubed up, constatly having to check it. He has now gone for the H+R's.
    ELIASGK74's Avatar
    Mar 2004
    greece
    47
    [ QUOTE ]
    [/ QUOTE ]
    back springs are knocking because of 55l so all are putting hr 80l
