Volks AutosChris Nott
    Jul 2012
    9
    Headlight removal
    Still struggling with this,
    audi s3
    1999 8l pre facelift
    how do you pop the indicators out?
    Has the bumper got to come off? If so wheres the bolts? Got the 4/5 on the slam panel
    Is there just the 2 bults on top of the headlight unit and the little locators on the bottom?
    Gettin vex'd with it now
    Jun 2012
    Essex
    215
    If you look at the back of the headlight, between headlight and indicator,you will see a grey / white Phillips head plastic screw, turn this so it clicks, then push down. The indicator will now pull out.
    The headlight is held in by 3 Torx bolts, 2 on top and one in the side, now revealed by removing the indicator, undo all of these and headlight will glide out.
    Ben
  1. Headlight Removal
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2007, 20:33
  2. Headlight removal!
    By Bridger in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2006, 23:11
  3. Headlight removal
    By blue03 in forum TT/TT-S/TT-RS Forum
    Last Post: 11th November 2006, 08:12
  4. Headlight removal without bumper?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2006, 20:22
  5. Headlight Removal
    By bioharry in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2006, 17:11
