Volks AutosEM Tuning
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    interior light and sunroof have minds of their own?
    hi all,
    i have a 1999 s3 and the drivers side interior light will be fine, then as im driveing along it will come on on its own but doesnt show on the dash as the door being open. if i change the switch to the off position it goes out. then when i get out i put it back to normal position it will work fine for a while. then do the same.
    also last week i left the sunroof open. and closed it with the key later on, and now it seems confused? now the sunroof wont tilt upwards. if i pull the switch down the sunroof slides back about 3-4 inches then when i turn the switch it opens fully. i get the same closeing it. i turn the switch to closed but it stops 3-4 inches from closed. then i press the switch up and it slides shut the last part.
    any help on either would be really apprieciated.
    thanks
    matt
    Apr 2010
    South Cheshire
    157
    Funny you should post this as I just did a search for "Interior light" as I am having a similar problem that has only just started.
    I don't have a sunroof but on my 2003 8L the interior light won't go off on auto when door is shut and the electric windows seem to have no electricity feed so even the lights inside the switches aren't on and the windows don't work.
    Does anyone have any ideas?
    I guess this may be to do with the features that connect with the key/central locking etc?
    Poke13/Jonny
  1. Interior lights and comfort indicators
    By antnee in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2011, 00:32
  2. Indicators With a Mind of Their Own!
    By Wai-Fan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2010, 16:34
  3. S3 Interior Lights and MPG
    By FugitiveB42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2010, 13:18
  4. Hazard lights with a mind of their own and ESP issues
    By V.I.P_UAE in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:29
  5. Interior lights and sunroof not working?
    By wayneharrow in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 17:15
Tags for this Thread
