Sky InsuranceVolks Autos
Results 1 to 9 of 9
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Centre lower bumper grille
    Just a quick one, noticed the front of my car didn't look quite right after a long drive. To my surprise the lower centre grille somehow worked it's way off and was sitting within the bumper recess... Not sure how this happened, I definitely didn't hit anything and there is no damage at all. My question is can it be fitted without removing the bumper?
    Mineral Grey [
    AMK
    s3cya's Avatar
    Apr 2012
    Exeter/newton abbot DEVON
    101
    post pics bud
    Colly's Avatar
    The Tangerine Machine
    Jan 2012
    Isle of Man
    277
    no it should have clips on the back. you will have to take the bumper off to put it on properly
    Sold 03 S3 Audi Exclusive Papaya Orange,
    New Car 05 Evo VIII FQ 340 MR 415bhp 400ftlbs
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Nice one Colly.
    Simple jobs are never straight forward with this car...
    Mineral Grey [
    AMK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    The centre grille is held on from behind using clips... to fix properly you ideally need to take the bumper off... not as bad a job as you may think...
    <tuffty/>
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Hope so Tuffty, I'll give it a go at the weekend.
    Mineral Grey [
    AMK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,460
    Dead easy dude...
    2 x screws under the bumper
    4 x screws (T25 torx typically) on inner arch
    4 x plastic 'pop rivets' across the top (I use a screw to pull the inner 'pin' out of them if the hole is visible else carefully push them through and make sure you see where they land)
    Disconnect wiring for fogs
    Disconnect hose connector for headlamp washers (I clamp it off else washer fluid will syphon out..)
    <tuffty/>
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Thanks for that, I'll finally be able to slot my s3 badge back on where it belongs as well whilst I'm at it!
    Mineral Grey [
    AMK
    Colly's Avatar
    Jan 2012
    Isle of Man
    277
    as tuffty said it should only take ten mins to get it off it didnt take me long the first time
  1. lower bumper grills
    By BL33SU in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 02:54
  2. Lower bumper grills
    By scottie 81 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th August 2010, 14:10
  3. S3 Lower bumper grill Needed
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2010, 08:24
  4. Replies: 1
    Last Post: 8th February 2010, 17:32
  5. LOWER BUMPER GRILL
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2009, 01:15
