Sky InsuranceEM Tuning
    BeeKay's Avatar
    Jun 2012
    Tipton, Dudley, United Kingdom, United Kingdom
    63
    My Horn has gone wild ( vag com )
    hello people , everythings been going good with the car for the past few weeks but now ive hit a glitch ( minor ) i changed some settings in vag com ( beep on lock , locks on 15 mph , and press twice to unlock passenger door ) ran this for a few weeks until last week when the alarm when ape sh** on me was at my girlfriends and it wouldent stop going off did notice it stopped beeping when i locked but thought nothing of it, beep came back for a while then when again and its not been there since and stil the alarm goes off every now and again randomly when parked up ..
    anyways ill come to the point ive done a auto scan on vag com and this is what it threw up being new to this stuff i have no idea what this could mean i know how to search the codes and what they mean but if anyone could help and suggest what it could be it would be appreciated !
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 019 BS
    Component: 1.6l 2V/R4 SIMOS HS3320
    Coding: 00011
    Shop #: WSC 06435
    2 Faults Found:
    00515 - Camshaft Position (Hall) Sensor (G40)
    27-00 - Implausible Signal
    00516 - Closed Throttle (Idle) Position Switch (F60)
    30-10 - Open or Short to B+ - Intermittent
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 03504
    Shop #: WSC 06435
    No fault code found.
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8L0 920 950 A
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 08442
    Shop #: WSC 65793
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1479028
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 16238
    Shop #: WSC 06435
    13 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to B+
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-10 - Internal Supply Voltage - Intermittent
    49-10 - No Communications - Intermittent
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    End -------------------------------------------------------
    again any help would be appreciated ! thanks H
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Sounds like a bad earth under the battery or your alarm module battery in the boot has leaked and causing havoc...
    BeeKay's Avatar
    Jun 2012
    63
    thanks for the quick reply where about in the boot woukd this battery be i know its only a small thing just have no idea where
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I think it is on the passenger side, right at the back below the light cluster...
  1. VAG COM fault code readings... possible coil pack gone down?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th March 2010, 16:47
  2. Who has a 2010MY A3 and VAG-COM??
    By chrisA3cabrio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2009, 16:38
  3. VAG COM Results Help Needed - Where have all my horses gone :( !?!
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2009, 12:49
  4. Has anyone in the UK bought VAG COM from the US?
    By Caesium in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd April 2008, 02:05
