    Jun 2008
    61
    Alternator Part Code - 2001 AMK S3
    Hey Folks,
    I don't get to use my car much and the last couple of times have had to charge the battery up - over the weekend I put the battery back in the car and went off for a bit of a drive - within an hour the battery warning light came on and then slowly the dash lit up like a Xmas tree - ESP light, ABS etc. I managed to get home but then could not start the car again before re-charging the battery - the car starts and drives fine when it is charged so I assume that the alternator is not charging the battery - unless anyone can offer any other suggestions?
    Could anyone tell me the correct part no. for the alternator on a 2001 S3 (AMK Engine) - I have looked on GSF/Euro Car Parts but there are 8 or 9 different ones and I don't know which is the right one!
    Thanks,
    Jon
    Feb 2006
    Lincolnshire
    714
    Before you totally condemn the alternator, have you checked the voltages with a voltmeter?
    You should be getting 14.6v or thereabouts at the alternator, and 13.6v or above at the battery terminals with the engine running.
    On mine, I was only 12v or less at the battery, which meant the charging cables and earths were the culprit. I replaced the cables and cleaned up the earth points underneath the battery tray and on the engine block, and I got my missing volts back!
    Yes, you guessed it, I only did the above after buying a new alternator!
    There is nothing special about the S3/AMK alternator, any of the listed ones will fit, although I went for the 120 Amp one, which is the same output as the original alternator.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
  1. Part code for the 18" OEM RS TT
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2007, 07:41
  2. part code for remote key
    By rasA4 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th November 2005, 20:28
  3. Servicing Cost and Part Codes
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2005, 12:44
  4. MAF Part code Please
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2005, 14:55
  5. Help with a part code please?
    Last Post: 3rd September 2004, 16:48
