Badger5AH Fabrications
Results 1 to 14 of 14
    Feb 2012
    bedfordshire
    748
    Worth getting my injectors cleaned
    As I have my intake manifold and injectors out to fit my oil catch can and sort out boost leaks is it worth me sending my injectors to get cleaned and serviced my car has done 49 thousand miles so I may do it or is there a way to do it myself ?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Do it yourself, buy a cleaner from amazin or maplins, loads of us have done, for £20 or so its a great investment and comes in handy.
    Feb 2012
    bedfordshire
    748
    Will have alook if there that cheap what are they call mate
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    I've been looking to get my injectors cleaned too. Has anyone changed the filter baskets etc. when DIY?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Feb 2012
    bedfordshire
    748
    Is it the ultrasonic cleaners ?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Ultrasonic cleaner;JPL 7000 Ultrasonic Cleaner with accessories: Amazon.co.uk: Electronics
    That's the one that me, Dani and well... Most of us have. Get some SeaClean solution too from Maplins
    Sea Clean;
    Seaclean 2 - Double Strength Concentrate : Ultrasonic Cleaners : Maplin Electronics
    Fill the bath with almost boiling water (boil a kettle, let the bubbles stop then pour it in) and mix a good amount of sea clean in there too, drop your injectors and FPR in there and do it for a cycle of the longest setting (480 seconds ish I think) then empty it, put fresh solution and water in, and repeat. Then leave the injectors in a warm place, (I used a hot air gun at about 100 Celsius from about 2 feet away) propped up so the water drains out, keep rotating them to get all the water out, and leave them to dry for ages, the longer you leave them to dry, the less problems you're likely to have afterwards.
    Hope this helps
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Feb 2012
    bedfordshire
    748
    Cool thanks everyone just ordered one with the solution
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Nice one no worries pal
    Mar 2012
    94
    can you not clean in petrol in the ultra sonic cleaner to stop any problems with the water?
    Contact admins for advertising
    TT 225 + a bit!!
    Feb 2012
    bedfordshire
    748
    Quote Originally Posted by Rich196 View Post
    Not sure but health and safety springs to mind
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Theres no need it works well, and does not have problems with water...
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    If you do use petrol, could you please film it and upload to youtube. The coroners might find it useful :P
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Errrr no... Ultrasonic cleaning uses sound waves to vibrate the molecules in water to lift dirt.
    Vibrating water molecules generates heat... Like how a microwave uses radiation to vibrate the water molecules in food to create heat.
    Petrol and heat in an open container aren't very clever things to put together
    Also, if by some miracle the ultrasonic cleaner DOESN'T ignite the fuel inside, would you really want 750ml of petrol in an open container?.. Bearing in mind the poor chap that was in the papers last year for pouring a rattle-can cap full (Probably 250ml) of petrol on to a BBQ to get it going... Put it this way... He was the only BBQ'd thing at THAT party.
    Bottom line, don't do it... Unless you're being framed... lol
  1. is the RNS-E worth getting?
    By ultramodz in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th March 2008, 02:08
  2. Is it worth getting VAG-Com and Cable
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2007, 10:40
  3. Injector cleaning..
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th March 2007, 20:03
  4. Is it worth getting the DIS??
    By willie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th January 2007, 18:45
  5. Downpipe, worth getting new flex joint welded in?
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2005, 09:21
