    Aug 2012
    The story of my dodgy alarm... any help welcome
    Hi everyone,
    Having found a lot of your posts very helpful in the past, I'm hoping that you can help me with my alarm issue.
    I have an Audi A3 1.9 turbo diesel, 2003, 5 door, and have driven it happily for 2 1/2 years, without alarm problems.
    I recently got a dog and for the first time used the internal sensor over-ride button, just below the driver's door latch.
    Quite randomly the siren started sounding whilst I was driving, then I had no issues for a few days. Now it seems I can't lock the car without the alarm going off after either a few minutes or a few hours.
    I have tried:
    locking it with/without the internal sensor
    locking it with the key instead of the fob
    removing the fuse for the anti-theft system
    none of which have worked.
    When the siren sounds, the hazards do not flash.
    When I open the car the siren continues, and will only silence when I start the engine.
    No warning lights appear for open doors or the boot.
    Any clues on what is affecting the sounder? It doesn't seem like the full alarm is going off, as no hazards etc.
    Baffled!
    Feb 2006
    Lincolnshire
    722
    First thing if possible would be to get it checked with VCDS to see what if any fault codes are present.
    It seems a bit coincidental, but the rechargeable batteries in the sirens do fail and leak over the circuit board causing all kinds of weird siren/alarm related issues. But, it does seem as if your problems started when you've used your interior sensor button, so it might not be that.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
  1. Instrument cluster fault... easy to swap cluster? Any help welcome!
    By car4kids in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2011, 19:45
  2. Boot not 'latching' enough to arm the alarm...any solutions/ideas?
    By impster in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th May 2009, 18:36
  3. The standard factory fitted A3 alarm (HELP)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 19:51
  4. audi a6 ecu problem? water in the electrics? any help out there?
    By darby7 in forum General Technical / How To
    Last Post: 20th July 2005, 10:31
  5. possible ecu problem? water in the car! any help out there....?
    By darby7 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2005, 19:53
