Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By cjsuk
Thread: Changing ariel to shark fin
    Jul 2012
    65
    Brought a 2003 a3 1.8t amazing car but hate the huge ariel on the back can you change it to a shark fin or something small and if so how ? Thankyou
    knoxie's Avatar
    K4OXE
    Aug 2011
    harlow, essex
    619
    some on has done it mate, he also wrapped his car to a really light blue but for the life of me i cant remember his name :facepalm
    Silver S3 02 AMK
    !!!!STANDARD S3 EXHAUST FOR SALE!!!!
    PM FOR DETAILS
    click here for
    IN AND AROUND THE M25 RING MEETS
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,747
    Quote Originally Posted by knoxie View Post
    it was damo mate! he did it! looks good too!
    Jul 2012
    65
    Haha well at least i know that it can be done can you just buy a smaller ariel because i swear no one has this size ariel its huge haha
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,747
    he wont mind me whoring his images! but i think it looks cool!
    Jul 2012
    65
    Any information, on how to do it and where to buy parts would be appriceated?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    Open the tailgate, remove the boot appeture seal, remove both rear "c" pillar trims and upper seat belt bolts, remove the rear interior light from the headlining along with the grab handles, remove the trims as needed, gently ease the lining down put your arm through with a 22mm-24mm spanner and undo your old aireal and pull it through gently, disconnect the aireal, refix your new one and put it back together!
    Jul 2012
    65
    Quote Originally Posted by Gregor11 View Post
    Thankyou mate, where can you buy them from? Could you send me a link for one that would fit? Also does it fit straight o? No fittings needed?
    G60DAN's Avatar
    Cornwall
    321
    I just pulled the light out in the rear and put and spanner up through the opening 10 minute job.
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    I'd be temped to try a dealer, a genuine Audi one would be good quality and fit well, plus I can't imagine them being that expensive! Or eBay! They are a straight swap over job, but the last one I changed was on a mk4 golf!
    AJC
    AJC's Avatar
    Surrey
    172
    The shark fin aerial if only designed for telephone and Sat Nav comms IIRC. The radio aerial on 8P cars is integrated into the rear windscreen so you won't get much of a radio reception by fitting this to an 8L. I think the owner acknowledged this in his thread but did it more for cosmetic reasons. I agree it suits the car much more but sadly won't work too well. I think there are alternatives to the standard long aerial but avoid the cheap ones on ebay as they're rubbish.
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    Mk5 golf aireal contains both radio and gps. BMW shark fin aireals will work, Mercedes shark fin will work
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,055
    AndyC-S3 pretty much nails it.
    There's no OEM swapout sharkfin, as they're primarily satcom aerials - so even if you get the right cable termination sorted out on a homebodged one, you'll get little or no radio reception because they're tuned to different bandwidths/impedance.
    Your stock 8L antenna is amplified, and all the gubbins for that are built into its base (ie between the headlining and the roof skin), if you ditch that you'll need an incredibly (read: implausibly) sensitive sharkfin to get anything like enough signal down the coax - I haven't looked, but there may be phantom-power amplified aftermarket sharkfins available - how well they'd match in terms of tuning and impedance may well vary quite wildly.
    All is not lost however... I fitted an aftermarket antenna to my 8L - combi AM/FM/DAB - so it is possible to get decent reception with an aftermarket antenna, but 1) that wasn't a sharkfin either 2) it wasn't exactly straightforward/cheap/cheerful... It was THIS antenna, but in a Blaupunkt packet. The Genglish product details on that page are tricky to make sense of, but I believe the amplifier in that one could either be phantom-powered via the coax, or given a dedicated supply. I seem to remember I phantom-powered mine (with the usual bog-standard silver tube modulator), and it worked perfectly with a Blaupunkt DAB-54 HU.
    There is a sharkfin on dabonwheel's catalogue, but I think it's DAB only.
    All the best,
    Rob.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,746
    Quote Originally Posted by AndyC-S3 View Post
    I don't have any worse radio reception, and that's even in reasonably remote parts of Australia (between Sydney and Canberra). Maybe I got a fluke. I did have to change the plug over though, it was the same connector as the car loom. I also seem to have an aireal in my rear window (as I found out when fixing the boot lights).
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    cjsuk's Avatar
    Feb 2012
    Leeds
    561
    I have a richbrook ariel using the short bit ( there is 2 bits included long and short) which looks good, was one of the first things I did due to the original Audi CB ariel looking pants lol.
    I would love a shark fin but to install one simply for looking good, i'm not going to bother (too much messing/money just for radio) BUT if I was to have an RNSE retro fitted this would be a route I would be prepared to go as it would be a practical toy as well as a good looking toy. That one ariel then becomes the heart of all things reception e.g. DVB-T, DAB, FM, GPS.
    jitvv likes this.
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Or if you want a shorter/fatter aerial just get one of these: Genuine VW Stubby Aerial Rod New Polo 2009> | eBay
    I fitted one a few weeks ago and it looks miles better. Just unscrew yours and screw this on, DONE!
    Just my 2penneth!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  1. Shark fin ariel on 2002 S3
    By StrmsekS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th April 2010, 22:37
  2. Shark Fin Ariel, Wiring Up!!!
    By Dani_B19 in forum In-Car Entertainment
    Last Post: 19th October 2009, 16:26
  3. Ariel shark fin
    By McGart in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2009, 08:50
  4. Shark fin Aerials
    By dgannon69 in forum General Chat
    Last Post: 3rd February 2006, 14:51
  5. Anyone for shark fin?
    By audi5e in forum General Chat
    Last Post: 3rd August 2005, 08:05
