Sky InsuranceEM Tuning
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    821
    Add Vex182 on Facebook
    Post What does this loose pipe do?
    On the back of my K04 is a flexy pipe that goes into a steel fixed one with a nut on the end, sits in the middle of the turbo, just behind the TIP. I guess ita likely to be oil, well when cleaning my tip I noticed it was loose! Very loose! Tinged it up with a 17mm and all seema good. I can upload a picture later when I am at my PC if that helps anyone. Thanks.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    EGT probe... fit in the hotside of the turbo and they tend to work loose... 17mm spanner (as you have used) and tighten...
    <tuffty/>
    Gregor-S3's Avatar
    Aug 2012
    Northampton
    170
    If its the pipe I think your taking about the it's an oil feed/return for the turbo, a picture will help, and it's a very important pipe
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Won't be the oil feed/drain if tightened by a 17mm spanner plus if the oil feed was loose you would soon know it as the oil light would come on pronto...
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    821
    Picture time!
    So thats it in the top right.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    yeh thats the EGT sensor.
    TD5 Land Rover Defender build
  1. What does this pipe do!? Part number please
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2010, 10:49
  2. What does this mean ??
    By 951 in forum Site Support & Announcements
    Last Post: 16th March 2007, 16:50
  3. What does this kight mean !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th March 2007, 21:12
  4. what does this symbol mean?
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 20:15
  5. what does this warrning light mean
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:23
