Badger5Volks Autos
Results 1 to 10 of 10
    Dec 2011
    396
    4 bar fuel pressure reglator
    hi is a 4 bar fuel regulator worth it
    beachbuggy's Avatar
    Surrey
    1,745
    Worth what?
    It basically makes your injectors bigger. Do you need bigger injectors?
    If you fit one it will wear your fuel pump out .
    You need to adjust the map really, it's not something you can fit for £10 and get instant gains.
    Colly's Avatar
    The Tangerine Machine
    Jan 2012
    Isle of Man
    277
    would it be a wothwile mod on a stage two s3 before i get it mapped?
    Sold 03 S3 Audi Exclusive Papaya Orange,
    New Car 05 Evo VIII FQ 340 MR 415bhp 400ftlbs
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    All a 4 bar FPR will do is add 15% more fuel which the ecu will adapt out more or less straight away...
    The only real reason to fit one is to make your injectors larger as Dan has already said but unless the map is adjusted to suit (and we are not talking generic stage 1 or 2 maps) then the ECU just adapts the fuel back out..
    If going hybrid or BT then you just buy injectors to suit... 4bar fpr will increase the strain on the fuel pump as Dan has already mentioned...
    Westy has managed to max his injectors out with his spec of tune and is currently using a 4bar fpr until he can get a set of 550cc injectors dialled in on a custom map... but its a temporary solution and will be back on a 3bar afterwards
    <tuffty/>
    Dec 2011
    396
    ok cool
    Colly's Avatar
    Jan 2012
    Isle of Man
    277
    the guy who im looking to map my car does fully custom maps on stage two cars is it worth it if your hoping to run late k04 territory with a proper map?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Quote Originally Posted by Colly View Post
    If you do exactly the same mods as me you'll find that you'll actually require larger injectors for a K04 on the limit. My standard injectors with a 4 bar FPR are still struggling to supply enough fuel.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Colly's Avatar
    Jan 2012
    Isle of Man
    277
    Quote Originally Posted by Westy View Post
    what are the main mods you have now westy ive started to read ur thread a few times but run out of time or fall asleep. have you got a list please?
    Westy's Avatar
    Dec 2008
    17,280
    Fall asleep lol is it that boring.
    I think the main mod that has really opened up the air flow is the large port head. The other airflow mods that I have that will effect your injectors are below:
    - new K04 turbo
    - XS exhaust manifold
    - AEB large port head
    - 3" down pipe
    - 3" Turbo Intake Pipe
    - Jetex cone filter
    - De-cat
    - Performance exhaust
    All the above have eliminated most restrictions found on a standard car. I am logging airflow to the equivelant of 285bhp but my injectors were running at 130%! With the 4 bar added they now run between 90-100%.
    I have bought a set of 550cc injectors and will be getting them mapped in the next few months.
    The issue with running injectors to or above their limit is that when they need to blast extra fuel into the engine to cool it they can't cause they are maxed.
    S3 Build Thread
    Colly's Avatar
    Jan 2012
    Isle of Man
    277
    thanks westy im just collecting all the parts for mine now ive fitted my cooler ive got a 3" pipeworx dp and decat to go onto it and i probably going to order a b5 tip this month then a few little bits the month after and the get it fully custom mapped hopefully
  1. 4 bar fuel pressure regulator
    By djdougalno1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2013, 09:44
  2. 4 bar fuel pressure regulator
    By Rick.S3 in forum For Sale/Wanted - Audi Parts
    Last Post: 1st August 2012, 19:36
  3. 4 Bar Fuel Pressure Regulator
    By Lee172 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2010, 15:11
  4. is a 4 bar fuel pressure regulator needed for a revo stag 2 remap
    By westu_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2010, 08:20
  5. 4 bar fuel pressure regulator?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2005, 17:59
