JMB RetrofitsChris Nott
Results 1 to 16 of 16
    Feb 2012
    bedfordshire
    737
    My S3 is driving me mad at the moment keeps on holding back ?
    My s3 2001 facelift has been driving me crazy for a while now when driving slowly or in traffic it's fine but when putting your foot down I boost what i should but it keeps on holding back sometimes it's ok, I thought it was a misfiring well feels like that so I thought I would change the spark plugs and coil packs, so changed them today still the same checked for faults prior that with my vag scanner and I'm getting 01279 longitudinal acceleration sensor which I knew about when my abs and esp lights were coming on in the past,
    but I cleared the fault and and it was fine for a while now it's come back surely this can't cause all these problems can it ? I have no other faults
    Could it be a boost leak sometimes sounds like it or something collapsing, I have checked around and seems ok was thinking the puck valve could be faulty or maybe n75 just don't know
    Please help
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    id go to a garage and have it smoke tested for boost/air leaks before anything else!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Well... do the obvious stuff first mate... check all the pipes under the inlet manifold... and by check I mean pull and poke them about... a tell tale sign is oil... if there is oil on the outside covering stuff then its been blow out from somewhere...
    A smoke test would help if there is someone local to you that can do it...
    Whats the idle like?...
    <tuffty/>
    Feb 2012
    bedfordshire
    737
    Yeah did think of that just finding one in the Bedfordshire area ?
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Paul, my idle is slightly bumpy, presume that again points to PCV leak?
    Feb 2012
    bedfordshire
    737
    <tuffty/>
    Saying that mate there is a little oil that I noticed today at the back to the right of the inlet manifold should I take of the mani to have a good look will try and take some pictures and post them up
    Feb 2012
    bedfordshire
    737
    Forgot to mention my idle is fine
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    Quote Originally Posted by dre_S3 View Post
    im in northampton with a smoke test machine if that helps?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Quote Originally Posted by JD09 View Post
    Potentially... happening more often these days... cars are getting old, oil + rubber = fail....
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Quote Originally Posted by Gregor11 View Post
    You have your own smoke tester? quite an expensive bit of kit to buy
    <tuffty/>
    JD09's Avatar
    Dec 2009
    3,080
    Just need to get involved under the bonnet more, get to grips with the car like I did with the Clio. Think the TIP refit and PCV needs to be the start of it. Potentially do the Catchcan as well.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,461
    Do it! :D
    <tuffty/>
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    <tuffty/>
    i wish mate, the garage i run has one! but i have access to it as and when
    Feb 2012
    bedfordshire
    737
    That would be great mate when would you be able to do it ? I'll sort you out obliviously
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    pm me your phone number and i'll give you a call to arrange, but potentially next saturday if thats any good to you as i'm away for the bank holiday weekend
    Feb 2012
    bedfordshire
    737
    Cool mate I have pm you
  1. My squeaky seat is driving me mad !
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2010, 19:58
  2. This is driving me MAD can anyone help?
    By robbie.kk in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th October 2009, 21:40
  3. creaking driving me mad
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2007, 03:45
  4. THE DRAGONS DRIVING ME MAD!!!!
    By imported_vishal in forum Volkswagen and other VAG
    Last Post: 5th January 2006, 09:49
  5. THE DRAGONS DRIVING ME MAD!!!!
    By imported_vishal in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2005, 12:04
