AH FabricationsVolks Autos
Results 1 to 14 of 14
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Toying with stage 2... costs and manufacturers to go for?
    Hi guys,
    So as I knew would happen; as the car is getting nice new brakes, I'm yearning after more poowwaarrrr!
    I know that for Stage 2, I need the following on top of my standard setup (stage 1 map, B5 TIP, Jetex and 007p)
    FMIC
    3" DP and cat/decat
    Possibly Exhaust, undecided as of yet
    What would be the best fitting and cost effective choice of products? I realise I also need a map, but plan on travelling to Bill's for fitting and mapping.
    Cheers for all input!
    Jamie
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Some people will suggest rods to you due to the age of the car. What's your budget?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    RIP S3dave
    May 2004
    nr Glos
    7,162
    mapped now?
    what boost does it run currently? (peak and hold)
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    JD09's Avatar
    Dec 2009
    3,080
    Post
    Quote Originally Posted by Westy View Post
    No budget in mind, rods hadn't crossed my mind...
    mapped now?
    Mapped by AMD Essex, but pretty certain it has a boost leak. I have a log that I'll post up again for you, Bill.
    edit; most recent logs, asked Paul and he mentioned it's requesting but not holding boost levels, which points to a leak. I still think (based on the 226 it pulled on AMD rollers pre B5 TIP and remap) that they have fitted it incorrectly. The car made 250horses post remap and TIP and goes through fuel like you wouldn't believe. Actually, maybe you would
    https://docs.google.com/spreadsheet/...DVmxmZ2c#gid=0
    Westy's Avatar
    Dec 2008
    17,273
    How many miles has the turbo covered? Any traces of oil if you remove the boost hose to the throttle body?
    S3 Build Thread
    JD09's Avatar
    Dec 2009
    3,080
    82k on an 02 plate. Seems to pull strong, no issues what so ever in my three year ownership (touches every piece of wood in the office).
    I haven't checked, but can do - what would this point to? You know me mate, as mechnically minded as a doormouse!
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by JD09 View Post
    Haha would point to failing turbo seals or blocked PCV system. Any oil going into the intake will hinder performance.
    S3 Build Thread
    JD09's Avatar
    Dec 2009
    3,080
    Why did I think that was only on older models? Perhaps the N24something bypass... I'll have a gander tonight when I fit my replacement Jetex.
    Still interested in any feedback btw Bill/Westy et al on Stg2.
    Westy's Avatar
    Dec 2008
    17,273
    Any turbo car can suffer from tired seals. The PCV (positive crankcase ventilation) is the pipe that comes off the top of the rocker cover and to the oil filter housing including the TIP. This is where it will blow oil into the TIP and will work it's way round to the inlet manifold.
    Other issues are tired MAF or N75.
    I asked about your budget as mine has spiralled out of control and is currently on revo stage 2 software. I have got to the extent when I need larger fuel injectors as mine are maxed out. That's custom map territory!
    Loads of info in my thread in my signature, including the full DIY engine rebuild. Take a gander.
    S3 Build Thread
    RIP S3dave
    May 2004
    nr Glos
    7,162
    smoke test a good place to start
    bill@badger5.co.uk
    JD09's Avatar
    Dec 2009
    3,080
    Thanks Bill, I'll get over to yours for this I think. Bad experiences with garages over this way, but necessary for MOTs by end of this month.
    Westy, cheers, had a read of the in depth PCV catch can fit. Will look at your thread as well once I get some time on my side this weekend. Ta!
    Westy's Avatar
    Dec 2008
    17,273
    You'll need more then a weekend. Just flick through all the pics till you see something interesting. And don't tell your gf/partner it was my fault when you spend a small fortune
    S3 Build Thread
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    JD what brakes you going for?
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    JD09's Avatar
    Dec 2009
    3,080
    This little lot buddy;
    Pagid disks all round. Ds2500s up front. Mintex rear pads and ATE super blue fluid.
    Will feed back!
  1. S4 (B6) Running Costs and What To Look For?
    By Veero in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st May 2012, 18:21
  2. People with CR Turbo Stage 3's and Turbos will billet compressor wheels
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 21:35
  3. Anyone for an S4 with 510lbs/ft torque and 492HP at the WHEELS?
    By Ram in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th February 2006, 20:41
  4. Servicing Cost and Part Codes
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2005, 12:44
  5. s3 servicing. costs? and is AMD as good as a Dealer?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2005, 21:21
