Results 1 to 10 of 10
    May 2011
    63
    Simple Question - Transfer box?
    All I need to know is if the transfer box is a separate sealed unit to the gearbox on the manual Quattros? Does it require it's own oil or does it share the oil from the gearbox?
    '03 8L A3 TDi Quattro
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    It shares the same oil ..
    May 2011
    63
    Cheers mate did wonder as I had a quick search on Google and there was some conflicting info regarding manual and auto boxes, thanks for clearing that up.
    Spider's Avatar
    May 2011
    50
    On the R32 there was a change around 2006 one had own one shared oil
    May 2011
    63
    Quote Originally Posted by Spider View Post
    Cheers Spider, I'm assuming then the separate oil applies to the post 2006 models then?
    Spider's Avatar
    May 2011
    50
    Yes it would seem so
    There was quite a but of confusion at Vw when my transfer box failed due to oil seal leak on prop
    As the gearbox was still full of oil
    Good to know that your vehicle is in good hands at the local dealers lol
    May 2011
    63
    You can't fault the dealers! This is partly why I'm asking. I have a slight leak on mine that I've identified is from the transfer box but it must be a very slight leak as I've checked the fluid level on my gearbox and it hasn't changed! Still I think I'll need to tackle the leak before there are any further issues. I suspect the seal may have been passed it's best when the box and transfer box were split a little while ago.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    ah... that would do it... there are 3 seals thats part of the bevel box/gearbox joint... they tend to be past thier best once taken off... mine weeped for a while after I did the clutch and that was with new seals but seems to have settled down now...
    Only prob was that my local dealer couldn't find the seals listed but it was due to ETKAs typically random categorisation as they were hidden somewhere where the parts guy had never seen before...
    <tuffty/>
    May 2011
    63
    I can imagine it's a pig of a job to replace those seals as well with the box in place? To be honest I should have had a bit more foresight when I had the box out to replace them there and then!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by Geoff-R View Post
    Its a bit of work yeah but doable...
    Drain gearbox oil, offside driveshaft off, disconnect probshaft, undo bolts holding it to box, undo bolts holding bracket to engine block and special tool to undo the bolt down the centre of the drive flange...
    <tuffty/>
  1. Transfer box oil leak
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 10:36
  2. simple question regarding vag-com
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd November 2007, 16:19
  3. Simple question Tyre change
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2007, 15:43
  4. A couple of simple questions ...
    By wigginer in forum General Technical / How To
    Last Post: 3rd August 2004, 21:03
  5. simple question about my 1.8t
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2003, 22:31
