Badger5JMB Retrofits
Results 1 to 11 of 11
Thread: wipers :(
    Aug 2012
    86
    wipers :(
    well the wipers now come on there own when i first start the car, and never go back to there original stop position, HELP HELP
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    remove the wiper arms from the car, start the car up or turn the ignition on, let the wiper linkage move down and settle, re-fix your wipers on in the correct position and you should be ok! may be a weak, worn linkage, or has the car recently had a screen fitted and the wipers not put back in the correct place etc??
    Aug 2012
    86
    Quote Originally Posted by Gregor11 View Post
    as soon as i turn the ignition on they start automatically then stop but in the wrong position ive let them settle, and moved them but still dont sit right they stop in a different place 99%of the time could it be possible relay issues?
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    It could be the switch, so even when your wiper stalk is in the off position, your wipers are on all the time?
    Aug 2012
    86
    no they wipe maybe 10 times then stop in as there off but always in the wrong position, then if i squirt or something a few times it sometimes goes in the right place
    Aug 2012
    86
    still in need of help lol, not so good on electics,
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    A wiper relay would be really cheap so won't hurt to try it, but my money would be on the switch, if it was the motor I'd imagine it'd do it all the time! Once the wipers have stopped have you tried to ever so slightly moved the switch about to see if anything happens? Also does the rear wiper come on? Last thing when the wipers park after first turning the key do they park in the correct place?
    Aug 2012
    86
    i shall try moving it slightly tomorrow, erm no rear wiper dont come on never tried it tbh, no they very rarely park in the correct place normally in the middle of the screen
    Greg-S3's Avatar
    Aug 2012
    Northampton
    280
    I'm almost 100% it's the switch! If it was the relay it would stay on constantly as its either on or off! So I'd go for a switch!
    Aug 2012
    86
    wheres the switch located? not the stalk is it?
    Jun 2013
    22
    Did you resolve this? My wipers are failing to park correctly.
  1. wiper mod
    By katanwara in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 18:35
  2. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
  3. New A3 Kaput Wipers
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2004, 22:12
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
