pthackeray22
well the wipers now come on there own when i first start the car, and never go back to there original stop position, HELP HELP
remove the wiper arms from the car, start the car up or turn the ignition on, let the wiper linkage move down and settle, re-fix your wipers on in the correct position and you should be ok! may be a weak, worn linkage, or has the car recently had a screen fitted and the wipers not put back in the correct place etc??
no they wipe maybe 10 times then stop in as there off but always in the wrong position, then if i squirt or something a few times it sometimes goes in the right placeIt could be the switch, so even when your wiper stalk is in the off position, your wipers are on all the time?
A wiper relay would be really cheap so won't hurt to try it, but my money would be on the switch, if it was the motor I'd imagine it'd do it all the time! Once the wipers have stopped have you tried to ever so slightly moved the switch about to see if anything happens? Also does the rear wiper come on? Last thing when the wipers park after first turning the key do they park in the correct place?
