Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    An annoying problem.....
    Hello ASN
    Everytime i have to steer hard at slow speeds (almost....and full lock) the car seems to jolt really badly. Occasionally the traction control light comes on and the car won't accelerate for a while and will suddenly kick in.
    Normally happens when I'm turning out of a junction. Its not every time but quite common, especially on one particular junction. I never gun it out of the junction, just go at a sensible speed.
    Anyone else had this before?
    What could it be?
    Next time i arrive at the junction ill turn the traction control off and see what happens.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I had this when running 18" x 8" wheels at ET25. Since I've. Changed back to standard wheels its been fine.
    What wheels/spacers do you have?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jan 2012
    Truro, Cornwall
    426
    ahhhh i see!
    I have 18 x 8.5 wheels.
    15mm spacers on the front, 25mm on the back.
    Used to have new style RS4 wheels on with no spacers and still did it.
    Westy's Avatar
    Dec 2008
    17,273
    It was only on full lock when mine used to have the issue. It's not a big problem just a little annoying. I wouldn't worry about it too much.
    S3 Build Thread
    Jan 2012
    Truro, Cornwall
    426
    ok thanks for that!!! yes annoying indeed! haha
    the worst is when you pull out in front of a car thinking "i can make that!" then your car decides to stick at 10mph while you watch the car you have just pulled out on come closer and closer to the back end of yours with an angry face appearing through the glass
    Apr 2012
    605
    turn off esp lol
    ribbon in the steering wheel might be gone
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    It's not the dreaded haldex clutch seizing / getting stuck on is it?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by vfr800 View Post
    It wasn't on mine. The car was designed with wheels of a specific size and offset and by changing that just upsets the turning circle on full lock.
    S3 Build Thread
    Jan 2012
    Truro, Cornwall
    426
    Hmmmm. I get a weird thing where sometimes if i slow down for a corner and the accelerate away i get like a thud/bang and a jolt come from the car. Ive always wondered what that was.
    Someone mentioned drop links as a possibility but i wonder if its connected to that at all?
    If it were to be something with the Haldex, is it an expensive replacement?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Dunno. The low speed problem is probably what Westy said.
    When was your Haldex fluid/filter last changed? It never hurts to be over cautious and change it regularly. It's an easy DIY if you can raise the back of the car up and you buy the special tool.
    To replace the haldex clutch is a bit of a pain/expensive I think - so best to look after it. Look at the Haldex threads - but this might not be your problem.
    Liam
  1. weird but annoying problem!....
    By limbo118118 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2010, 11:00
  2. Annoying problem?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2008, 19:28
  3. Annoying Problem?
    Last Post: 25th November 2008, 19:10
  4. Help me with two annoying problems
    By Freethy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2007, 18:11
  5. Annoying problems
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st December 2004, 22:26
