JMB RetrofitsEM Tuning
Results 1 to 17 of 17
    Feb 2012
    Denmark, Copenhagen
    199
    What dyno to belive
    I had my A3 dynoed a few days after exaust fitment. The result was underwhelming. It was dynoed at 205 back when i had it remapped, long before any exaust. (Maxeffect = Hp, Maxmoment = Torque)
    Disappointed, i went to the shop that did the remap, and he offered me a free dyno test to see what was up. Well it came out quite different.
    His explanation was that first of all, the dyno itself the other shop is using, is considered outdated, and that the blower or whatever its called (The cooler they put in front of the car), was too small. The one he himself was using, was actually massive. Atleast 3 times as big.
    Its not thats its really that important, because the car is really fast now, but those 2 results are quite different, and i have no idea what to belive.
    The car is an A3 1.8T AUM 150hp model with a remap, turboback milltek, GFB recirc valve and a pipercross panel filter. Nothing else has been done to it.
    warren_S5's Avatar
    Oct 2007
    7,158
    Believe none; that way you won't agonise over something that is largely unimportant.
    By all means use a rolling road to tune a car that isn't running right / optimally, but the inconsistency in the way these things are operated and work is why the phrase dyno lottery exists.
    Feb 2012
    Denmark, Copenhagen
    199
    I get what you are saying warren, i just cant help it :<
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    I'd be looking at the airflow and seeing what it's reading mate.
    At the end of the day, if you're happy with it then that's all that matters. there is always a bit of a dyno lottery, some read high, some read low.
    Looking at Mass airflow, and dividing the value by 0.8 often gives a good indication of bhp.
    Feb 2012
    Denmark, Copenhagen
    199
    Air on the first pic reads:
    Airpressure: 1011mb
    Airtemp: 29c
    Airmoisture: 65%
    Thats the direct translation, not sure if thats the correct technical terms in english.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,368
    He means the Airflow as measured by your engines ECU.
    You need to do some logging with Vagcom/VCDS and see what airflow figures its reporting.
    TD5 Land Rover Defender build
    Feb 2012
    Denmark, Copenhagen
    199
    Oh. Well thats not happening any time soon, unless i somehow get my hands on a really cheap cable from china.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Believe the highest mate, to be honest if any dyno said my car made 300bhp on a standard map i'd believe it hahaha
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    Take your engine out and fit it to a engine dyno SuperFlow Engine Dynamometer with this you will get a very accurate reading
    if you like to find out what power your engine is making at the wheel then you need to get it on a hub dyno
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Feb 2012
    Denmark, Copenhagen
    199
    I'll get right on that, Andrew :D
    "Stick a V8 in it!"
    15,368
    Quote Originally Posted by anderswhk View Post
    Chinese cable should work fine.
    Feb 2012
    Denmark, Copenhagen
    199
    Can you recommend any VAGCOM-like software that are free...ish?
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by Andrew@A.L.D View Post
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Rolling roads are very good tuning tool, they are not very good to test power outputs due to the multitude of influencing factors.
    The best way is using a flat piece of road, and measuring the time it takes to accelerate between two speeds. You get a true reflection of real world performance.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    RIP S3dave
    May 2004
    nr Glos
    7,161
    before run done?
    what was it
    what was it afterwards?
    gains=gains
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,764
    Is the MAF /0.8 ALWAYS a true indication?
    Regardless of engine mods and spec?
    Noggy Blue 2001 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by S3 Paul View Post
    Not always no....
    <tuffty/>
  1. Finally put my car on the Dyno... what do you guys think?
    By Gryphon001 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th August 2009, 20:51
  2. What 's your job
    By richyboy in forum General Chat
    Last Post: 8th March 2003, 12:38
  3. So what does it actually do
    By Shao_khan in forum General Technical / How To
    Last Post: 13th February 2003, 14:15
  4. What kind of company car do you get?
    By worfke in forum General Chat
    Last Post: 13th January 2003, 08:58
  5. Seeing as it's New Year what's your calendar??
    By JohnH in forum General Chat
    Last Post: 10th January 2003, 17:10
