Badger5AH Fabrications
Results 1 to 14 of 14
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    Fuel pump failure
    Well came out of morrisons tonight and the car started and then cut out straight away called my mate who is a VW tech and he checked the wiring and relay, all ok. The pump it seems has just had it!
    The pump has been steadily getting louder and louder over the last week,it's been buzzing like when it first primes constantly as I've been driving.
    im quite lucky as I work in a VW dealer with TPS next door so hopefully I can have the part in by thursday latest.
    I love my S3 but these things are sent to try us!
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    Oct 2006
    North Herts
    168
    Its just one of them things, these cars are getting old now, and electrical items fail, atleast you work in a place you can get it all sorted. Let us know how you get on mate, You'll be back in the S3 before you know it!
    Jit
    Audi S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Seeing a lot more of this recently... fuel pumps getting tired...
    <tuffty/>
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    198
    Yeah I know, its a 51 late so shes getting on now so I fully expect little problems.
    I suspect my recently revo remap has shall we say "highlighted" an old part that was getting tired ha ha
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Most people who upgrade there fuel pump use second hand ones. I've alo see the walbro ones on eBay but how much are they from the stealers?just curious as I'm sure we will all need to replace ours if we haven't already.
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Mine just died tonight. Can't call it names really at almost 10yrs old now...
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I've notice when my tank is less than half full I have to give the pump a little more time to prime before I start it.
    I think mine might on borrowed time.
    What's with the Walbro pumps? Do they go inline?
    or do you just take out the old one from the tank and replace the motor with something like this Fuel pump Audi A3, TT, 1.8T | eBay or NEW AUDI S3 S4 RS4 RS6 RS8 UPRATED HIGH FLOW FUEL PUMP | eBay ?
    Are there any guide on doing this?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Been there, done this. Get an OEM one from TPS/dealer etc. Don't get one from GSF/ECP etc unless you are guaranteed to get the full pump harness as well as the pump itself. Changing the whole harness is a relatively simple job...as long as you like the smell of petrol!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    The remaps help kill the old pumps off.
    It's a pretty stinky job to do, you'll be high as a kite on petrol fumes! Rear bench seat out, peel carpet back, then it's a pretty simple task of undoing the bolts fixing the pump into the tank and swapping the pump.
    A pump from VW cost me £220+VAT
    Some pics of when I did mine here:
    W3STY's Progress Thread
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    When you replaced the pump did you have to calibrate the float sensor?
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by vfr800 View Post
    I didn't and not heard that mentioned before. You just drop it in and the float is on an arm which is the length specifically for that size tank.
    S3 Build Thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Westy View Post
    Ah ok - I just assumed that you'd need to do something with VCDS to make sure the fuel gauge showed the correct amount of fuel.
    Westy's Avatar
    Dec 2008
    17,273
    I know there are some blocks in VCDS that can be fiddles but I've done 2 of these on S3s now and it's been fine both times.
    S3 Build Thread
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Ditto, just make sure you don't get the arm caught in all the cables/hoses.
    > S3 225 (03) - OEM+
    View: My S3 diary
  1. fuel pump failure
    By S3SYD in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2008, 22:56
  2. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
  3. Fuel pump change
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2005, 10:06
  4. Fuel pump problems
    By nunzio42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 12:09
  5. Fuel Pump Noise
    By europabluea6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th September 2003, 18:15
