Fuel pump failure
scotty_24
Newcastle upon Tyne
Well came out of morrisons tonight and the car started and then cut out straight away :( called my mate who is a VW tech and he checked the wiring and relay, all ok. The pump it seems has just had it!
The pump has been steadily getting louder and louder over the last week,it's been buzzing like when it first primes constantly as I've been driving.
im quite lucky as I work in a VW dealer with TPS next door so hopefully I can have the part in by thursday latest.
I love my S3 but these things are sent to try us!
Its just one of them things, these cars are getting old now, and electrical items fail, atleast you work in a place you can get it all sorted. Let us know how you get on mate, You'll be back in the S3 :blackrs4: before you know it!
Seeing a lot more of this recently... fuel pumps getting tired...
<tuffty/>
Yeah I know, its a 51 late so shes getting on now so I fully expect little problems.
I suspect my recently revo remap has shall we say "highlighted" an old part that was getting tired ha ha
Most people who upgrade there fuel pump use second hand ones. I've alo see the walbro ones on eBay but how much are they from the stealers?just curious as I'm sure we will all need to replace ours if we haven't already.
Been there, done this. Get an OEM one from TPS/dealer etc. Don't get one from GSF/ECP etc unless you are guaranteed to get the full pump harness as well as the pump itself. Changing the whole harness is a relatively simple job...as long as you like the smell of petrol!
When you replaced the pump did you have to calibrate the float sensor?
I didn't and not heard that mentioned before. You just drop it in and the float is on an arm which is the length specifically for that size tank.
Ah ok - I just assumed that you'd need to do something with VCDS to make sure the fuel gauge showed the correct amount of fuel.
Ditto, just make sure you don't get the arm caught in all the cables/hoses.
728
769
546
