Chris NottEM Tuning
Results 1 to 7 of 7
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Brake pads, discs and fluid change/upgrade
    Having all this done on Saturday morning, as well as a service and MOT. The question is, am I mad not to replace the standard hoses at the same time? Thinking about buying HEL lines or Goodridge...
    Car is an S3 BAM 2002 - it's having Padid plain discs front and rear, mintex rear pads, DS2500 front pads and ATE Super Blue fluid...!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    The hose kits available only replace the fronts and the two that go from the body to the rear arms... they don't normally replace the part flexi/hard pipe that goes to the calipers
    As std I think they are 'braided' anyway but the decent stuff (Bill sells lines for Brembos etc normally) use stainless (not plated) fittings so are a good alternative
    <tuffty/>
    JD09's Avatar
    Dec 2009
    3,080
    Ah OK, thanks Paul. I think my rears are the ones on their way out so may just replace as and when.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    I would imagine they can be check once up on a ramp...
    <tuffty/>
    JD09's Avatar
    Dec 2009
    3,080
    Sailed through service and MOT and pads and discs are wearing evenly I'm pleased to say, so been fitted correctly!
    However, I have a lot of fluid left in the ATE super blue tin. And by a lot, I mean over half full... I know the system takes less than 1 litre, but does this concern anyone else?
    Feb 2008
    2,817
    Where did you get the discs from jd? You got any pics?
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,592
    I used nearly a ltr of ATE blue as I just wanted to be sure I had bled it all through... I went round a few times to be sure...
    <tuffty/>
  1. User Review: EBC Brakes - Ultimax Discs and Yellowstuff Pads
    By Reload in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2012, 07:35
  2. Brake pads/Discs...
    By Wozski in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 08:47
  3. B6 S4 brake pad/disc costs
    By BillTheButcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th May 2010, 13:30
  4. Rear Brake Pads & Disc Replacement
    By maddoggydawg in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th January 2009, 20:43
  5. Brake pad/disc question (Quattro)
    By jimmi in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2007, 12:52
