Chris NottSky Insurance
Results 1 to 9 of 9
    Adam P's Avatar
    May 2012
    Southampton
    321
    Milteck Exhaust Fitement Question
    Hi guys,
    My current back box is damaged on my s3 8l and needs replacing. I have found a miltec back box which has been removed from the newer shape s3 the 8p i think its called. Will i be able to get this to fit without too much hassle? ie: moving hangers, welding and having pipe made up. Or should i just steer clear?
    Thanks in advance.
    Adam
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    No mate... won't fit, different beast altogether...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    I say try it. If you can weld etc, then give it a go.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    8L S3 Milltek
    8P S3 Milltek
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    ...and the room to play with..
    Problem you have is the 8L and 8P pipes run different sides of the prop... the only place you could cross over potentially is in the rear section past the rear diff... bit like this..
    ... but I can't see there being the room with the Milltek 8P box...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,453
    I reckon the box could be done, but not the mid section.
    I bet it would sound great too, the 8l milltek is gigantic, 8p looks a lot more compact and prob flows better
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    ...8p looks a lot more compact and prob flows better
    ..apart from the tight kink to get the pipework over to the other side...
    8L Milltek flows fine... certainly more than the std back box....
    <tuffty/>
    Adam P's Avatar
    May 2012
    Southampton
    321
    Cheers for the info and responses guys much appreciated.
    Can you recommend anyone or anywhere i can get a nice aftermarket back box or system without breaking the bank!!??
    Would be happy with a cat back, i like the oval shape similar to the leon cupra r.
    Adam
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Quote Originally Posted by Adam P View Post
    Adam
    https://www.jetex.co.uk/jetex/store/...productId=1699
    <tuffty/>
  1. Exhaust/Engine Question Help Needed ASAP
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2009, 17:36
  2. Miltek Exhaust Question
    By ash_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2007, 20:25
  3. Replies: 0
    Last Post: 18th November 2004, 17:54
  4. Exhaust and Chipping Questions??
    By imported_BiTurboS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2004, 21:06
  5. Exhaust question...Don't you hate me?
    By HotSauce in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th July 2004, 06:54
