Chris NottJMB Retrofits
Results 1 to 15 of 15
    Sep 2009
    102
    Old style RS4 replica wheels with 235/40/18 tires
    Will they fit my A3?
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Are they 5 x 100?
    What's the offset?
    And those tyres are slightly too big, you could use them, but your speedo wouldn't be very accurate. You need 225/40
    colicabcadam
    why would the speedo be out if a tyre was wider ? confused lol
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Because the rolling circumference has increased by 25.2mm pushing the speedo out by -1.24%...not much out, but still out.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    colicabcadam
    Quote Originally Posted by [Dave B] View Post
    if the tyre is wider ? i thought the wheel size and profile of the tyre determened the circumferance ?
    so a 355/40/18 has a larger cirumference than a 205/40/18 ???
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    > S3 225 (03) - OEM+
    View: My S3 diary
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    the profile number is a % of the width.
    So a 225 / 40 means the height of the tyre is 40% of 225.
    A 335 / 40 is 40% of 335.
    Therefore, you make it wider, it gets taller too.
    If you look at the tyres fitted to the RS4 for instance, they used 255/35r18's, which are pretty much identical in circumference to the 225/40r18's everyone uses on the S4.
    TD5 Land Rover Defender build
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    The profile, in this case 40, is a percentage of the width. Its not a size, not 40mm.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,563
    Quote Originally Posted by colicabcadam View Post
    YES.
    Sep 2009
    102
    Are they 5 x 100?
    What's the offset?
    They are pcd 100 and 112. Will they cause issues will rubbing on the wheel arch?
    colicabcadam
    oh - nice to know this !!!!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by sekenzo View Post
    depends on width and offset.
    But at a guess they will be the same as mine, 18 x 8, offset of 45, meaning you will need spacers to clear thew struts, but no arch rubbing no. For the record I run 15 and 20mm spacers.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,563
    replicas are generally the correct offset @ET35, but later ones are ET45. With 235 tyres, I would say they will scrub on your arches on an A3, an S3 would be ok, as they have a bit more room to play with being wider etc.
    Jpd89's Avatar
    Jun 2012
    West Sussex
    105
    Can I jump in here as well? Trying to see if 9jx18 wheels with 35 offset would fit? Would need 20mm adapters as well so would the offset go to 15 or 55?!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by Jpd89 View Post
    offset would go to 15 with 20mm spacers.
    use this:
    Wheel Offset Calculator
    measure your current clearance and then put the wheel specs in
  1. Old Style RS4 19" Wheel's
    By CMD in forum For Sale/Wanted - Audi Parts
    Last Post: 19th August 2011, 14:08
  2. Replies: 0
    Last Post: 30th September 2010, 11:45
  3. RS4 replica wheels
    By FrankG in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2004, 22:00
  4. RS4 replica wheels
    By FrankG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2004, 08:41
