Volks AutosMonster Motorsport
Results 1 to 13 of 13
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    S3 outer cv boot?
    Hi
    Mine has a split form and is losing grease. To replace the boot do I need to remove the whole drive shaft from the car? Or can I remove the hub and work on it supported in situ?
    If it's a small split, do I need to completely clean the old grease out and re-grease? or is it always best to do this incase of any contamination?
    Oh and which is the correct sealey or laser tool to replace the CV boot clips?
    Thanks, Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Easier to remove the shaft tbh... I normally clean as much of the old grease out as poss... I have even taken the joint apart before to clean but not recommended if you are unsure as it can be a bugger to put back together..
    there is a thread in the stickies covering shaft removal and replacing the inboard gaitor but the outer isn't much different... just have to tap it off straight so the joint stays in one piece
    <tuffty/>
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Thanks Tufty.
    I've read that thread several times through - thought I might get referred back to it
    Looks like a straight forward, albeit messy, job.
    Is it best to use new bolts to secure the shaft to the transmission/gearbox?
    Liam
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    They are stretch bolts IIRC so its recommended... I didn't change mine at the time but that was my decision...
    <tuffty/>
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Thanks again.
    I'll try to take some pics while I'm doing it to add to the CV boot knowledge base.
    Liam
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Grrrr.
    Just rereading the guides and some elsa stuff off the internet before I get stuck in with the job, i need a torque wrench capable of 240nM.
    Mine only goes up to 200
    Any one near Milton Keynes got a bigger torque wrench I could borrow for beer?
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    534
    Got a 300Nm in Camberley...but that isn't exactly near
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Is it 240Nm for the shaft? If so, I wouldn't remove it. I just took the hub off to replace the outer CV boot I'd have thought taking the shaft out is making more work than necessary.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Squirrelofdoom View Post
    Thanks, bit too far, Halfords have a pro one for about £80, I'm thinking about getting that. The cheapest Teng torque wrench which covers this is about £103 + delivery.
    Quote Originally Posted by Aaron TDIQ View Post
    Yes. Oh that's an idea, would save the palava/sequence of tightening and undoing the big nut. But I want to degrease and grease it properly ... is that possible while on the hub without nadgering anything else?
    Liam
    Oct 2011
    760
    Changed mine with something similar to this
    AUDI S3 QUATTRO DRIVESHAFT CV JOINT OUTER BOOTKIT CV BOOT KIT GAITER STRETCH NEW | eBay
    i didnt take of the drive shaft.
    just undid the hub, track rod and pulled away the hub, used the cone to slip the boot on.
    quite an easy job and passed mot.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by vfr800 View Post
    Yep you can as you got to get the boot over the joint, so yes you can clean it and apply new grease to the joint in situ.
    8L IS DE BEST
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Took 5.5 hours to do the CVJ boot. Reason it took so long is down the the previous owner employing f*cktards to do work on the car.
    Is the end of my drive shaft supposed to look like this?
    It's mushroomed/peened over so putting the bolt in and out is difficult. I was an epic mission (for me) to remove and put it back into the hub. How the hell can it be this damaged?
    Also is the circlip suppose to look like this when the outer CVJ and shaft are split?
    It's not quite symmetrical I think the circlip was bent when it was put back on. I had to use a bearing puller to separate the shaft and CVJ.
    There were several points where I wished I'd paid the garage to do this but it's done now.
    Liam
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Any one?
  1. audi allroad rear outer cv boots
    By ms1083 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th March 2012, 23:36
  2. CHANGING OUTER CV BOOT ON A 2004 AUDI A3 8P
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2010, 15:35
  3. how hard to do outer cv boot on 2.8q?
    By nomadx in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2009, 09:30
  4. Outer CV joint boot clamp
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2008, 17:28
  5. inner and outer CV boots!
    By sitrials in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2008, 14:27
