Volks AutosSky Insurance
Results 1 to 8 of 8
    Sep 2010
    Devon
    756
    Changed 1.8T gearbox, now only have 1st, 2nd and 4th??!!
    Hi all just swapped a blown gearbox out of a 1999 AGU and put in a good, working box from a golf AGU, they had the same part numbers and the same fitment. Started up the A3 and all sounds good, no dodgy noises from the clutch or grinding whilst changing gears however it will only select 1st, 2nd and 4th, does anybody have any suggestions please as this has not been the easyist or most fun jobs so far...
    Many thanks
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hi dude, nothing bloking the linkage/forks?
    Sep 2010
    Devon
    756
    Nothing where it shouldn't be...all is set up exactly the way it came off! Damn thing
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    On my old corsa, you could lift the gater and put a pin in the linkage just before reverse, you would then tighten all the linkage fully tight in its optimal placement. Dunno if anything i available for the VAG boxes?
    Dave
    Sep 2010
    Devon
    756
    I'm not sure either but thanks for the tip, I'll be looking in to that.....
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,387
    yup, adjust the cable ends mate. What works on one box might not work on the next, so do a reset on the linkages and see what happens
    Sep 2010
    Devon
    756
    Cheers lads...I'll have a fiddle with that tomorrow, after nearly two days of messing around with this I'm having a well earned night off and a glass of vino
  1. Changed the heater matrix and now I have this error!
    By Westy in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st November 2011, 13:37
  2. Which Auto gearbox do i have?
    By gadgesxi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2009, 18:07
  3. Car serviced by Audi just over a week ago now I have a blown head gasket! PLEASE HELP
    By Solani in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2008, 07:04
  4. Gearbox Problem - Lost 1st/2nd Gear!
    By deano_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 08:46
  5. What Gearbox do you have ?
    By spiider in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2004, 16:22
