EM TuningMonster Motorsport
    Erf
    Oct 2006
    Kingston
    231
    Wheel speed sensor
    Hi Guys,
    I've been getting the following error with vagcom:
    Address 03: ABS Brakes Labels: Redir Fail!
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FAAB42979
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    35-10 - - - Intermittent
    I replaced both the front right and front left sensors but i'm still getting the above error!
    Are right and left sesnors interchangeable? I know the left works so was hoping to test it on the front right to see if the (new) sensor is also dodgy or whether it could be something else.
    Any advice?
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Where did you get the replacement sensor from? Have you cleared the fault code after changing it?
    I had this error a few weeks ago and replaced the front right with a new sensor from TPS, cleared the code and hey presto, Robert's your mothers brother....
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
  1. ABS Wheel Speed Sensor "Tone Ring" problem
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd July 2010, 21:47
  2. **READ ME** ABS wheel Speed sensor.....WARNING!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 14:01
  3. Wheel Speed Sensor Problem...... again!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2009, 18:38
  4. ABS Throwing fault Wheel Speed Sensor
    Last Post: 16th January 2009, 15:15
  5. How to replace OSF wheel speed sensor wire??
    By gjrquattro in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2008, 13:34
