EM TuningSky Insurance
    Apr 2012
    93
    master cylinder nipple size, witch one of these ??
    hi all, could some one please tell me witch one of these two nipples will fit my master cylinder on a 1999 s3, thanks in advance.
    no1, ebay Item number: CAR/MOTORBIKE BRAKE BLEED SCREW/NIPPLE 6MM X 38 VW AUDI | eBay
    no2 ebay Item number: BRAKE BLEED SCREW CAR MOTORBIKE NIPPLE 7mmx1mm VW AUDI | eBay
    Apr 2012
    93
    hi all, could some one please tell me witch one of these three nipples will fit my master cylinder on a 1999 s3, thanks in advance.
    no3 ebayItem number: BRAKE BLEED SCREW CAR MOTORBIKE 6mmx1mmx38mm VW AUDI | eBay
    sorry there are 3differnt ones.
    thanks again
    Apr 2012
    93
    Any 1 ? Please.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    I have edited your posts as posting links is more likely to get you a response than somebody having to copy and paste the individual numbers in... if you expect people to help you then at least make it easier for them to do so
    Anyhoo...
    I am not certain as to what the MC ones are but std bleed nipples on a VAG car are M10x1 and the MC ones are much smaller...
    Tbh youneed to remove the remaining nipple you have and measure it... if you at least measure the diameter you will have a start point..
    You will prob need to remove the MC anyway to remove whats left of the broken nipple anyway...
    <tuffty/>
  1. Master Cylinder Bleed Nipples...
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2011, 14:27
  2. Clutch Master cylinder issues.....
    By nlw73 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 08:59
  3. Get a Cable Knit Cardy and one of these....
    By IanL-S3 in forum Other Brands & Models
    Last Post: 28th May 2005, 21:18
  4. Does my A4 have one of these as standard???
    By teejoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2004, 04:15
  5. I've just been out in one of these....
    By AL_B in forum Other Brands & Models
    Last Post: 21st November 2003, 16:21
