Sky InsuranceBadger5
Results 1 to 12 of 12
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Fault code again 16725 cam sensor
    Rebuilt the engine after the piston ring problem and added cams to the rebuild
    I've been having problems with timing it back up first i was getting 17748 Camshaft/Crankshaft Position Sensors (B2) - Out of Sequence A, but now thats gone i have the 16725 cam position sensor
    Am i thinking that the timing between the two cams are out thous throwing up this code??
    My engine is a really pain time up as i have no marks on the flywheel ( billet steel one ) Its very hard to see the marks on the fluidamper pulley, No marks on the cam pulley as its a Cat cams one
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    press on gears on your cams? the keyway visible.. tdc #1 is probably best physical tdc and make your own mark. I do this as I like to know where I am starting from on my markings, not having much faith in other markings.. to vague etc
    tdc#1, cam cover off ( a pia no doubt on cts kit) and see where the keyways are on the cam gears relative to the small arrows on the cam caps..
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,469
    Yes press on gears, keyway not that visible, from the ends yes but not so much from above
    Cam cover is easy to get off now as it has been modified to clear the waste gate
    FOR SALE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    I always make a mark on the crank sprocket, and on the oil pump casing behind it that shows TDC (usually pointing streight down at TDC). The marks on the big crank pulley are useless as the pulley can move a good few degrees in either direction on its bolts.
    As above there should be a square on each cam which lines up with the arrows on the rear cap cap.
    Depending on how the tensioner feels they dont always line up 100% on the intake side, but the exhaust should be bob on, and there should be 16 chain rollers between the marks.
    TD5 Land Rover Defender build
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by Andrew@A.L.D View Post
    got any pictures of what you see?
    physical TDC #1 and a picture of the cam sprockets?
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    16725 = 16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Wiring from/to Camshaft Position Sensor (G40) faulty
    • Camshaft Position Sensor (G40) faulty
    • Timing misaligned
    Possible Solutions
    • Check Wiring from/to Camshaft Position Sensor (G40)
    • Check Camshaft Position Sensor (G40)
    • Check Timing
    Category:
    This would seem to be more a sensor/wiring related fault code than its reporting its in the wrong positions, as thats usually setpoint not reached over advanced or over retarded...
    your 1st fault code was top to bottom error.. crank to cams wrong but if thats now gone, presuming you moved the belt a tooth or so on the cam gear, then the remaining one might be the cam sensors not working, or wiring to it... also check for the pin not being bent over in the cam sensor.. (seen that before)
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,469
    No pictures
    Off to do the cams in a few minutes
    FOR SALE
    Jun 2009
    Leeds
    3,469
    I forgot i also did have a 16727 which is a faulty camshaft sensor
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,175
    lmao
    nothing like not giving all the info is there Andrew - ffs dude...
    lol
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,469
    All of the above codes have gone but now have 2 new ones, fitted new cam sensor
    16684 and 16685 random misfire and misfire no 1 ?
    FOR SALE
    RIP S3dave
    May 2004
    nr Glos
    7,175
    16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
    Possible Causes
    • Air Intake System leaking
    • Fuel Supply faulty
    • Injector(s) faulty
    • Ignition Cable(s) and/or Spark Plug(s) faulty
    • Ignition Coil(s) faulty
    • Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
    Possible Solutions
    • Check Misfire Recognition
    • Check Air Intake System
    • Check Fuel Supply
    • Check Injector(s) and Injector Sealing
    • Check Ignition Cable(s) and Spark Plug(s)
    • Check Ignition Coil(s)
    • Check Exhaust Gas Recirculation (EGR) Valve (N18)
    Special Notes
    • This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
    16685/P0301/000769 - Cylinder 1 Misfire Detected
    Possible Causes
    • Ignition system
    • Fuel injectors
    • Fuel pressure
    • Running out of fuel
    • EVAP canister purge valve
    • Evaporative emission system
    • Low compression
    • Base engine problems
    • Controle Module damaged
    Special Notes
    • This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
    www.badger5.biz
    bill@badger5.co.uk
    Jun 2009
    Leeds
    3,469
    I'll leave it today and try tomorrow
    FOR SALE
  1. ESP fault code 01435 Brake Pressure Sensor - Common fault apparently
    By DenniS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 13:50
  2. MAP sensor fault code 16492
    By RLilleyman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2009, 20:07
  3. AF FSI 2.0 Cam Sensor fault
    By RLilleyman in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th September 2009, 18:42
  4. A4 2.0 FSI Cam Sensor Fault
    Last Post: 11th September 2009, 17:51
  5. Engine Speed Sensor Fault code 16706
    By Felon in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2008, 08:07
