AH FabricationsSky Insurance
Results 1 to 19 of 19
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question A3 1.8 non-turbo - Fuel guage sensor/sender
    Hi all.
    Our A3's fuel guage is all over the place at the moment, so I'm going to clean/replace it.
    Having done a search, I have found that it is located under the rear seats, but which side is it (there are two round items), and which sensor is the guage sender?
    Many thanks
    *WANTED* AUDI CD PLAYER
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Anyone know this?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Drivers side one and the fuel sender is integrated to the fuel pump unit... not sure if its available as a seperate unit... buy one from a dealer though as after market parts don't seem to fit or work properly..
    <tuffty/>
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Sounds like a bit of a mish.
    Anyone got pics of the part I need to remove?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Anyone happen to have a picture of what I need to remove?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    A bit like these...
    <tuffty/>
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Cheers Tuffty.
    If that's the fuel pump, where on that is the sender?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    The floaty bit on the side
    <tuffty/>
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Haha cool, cheers.
    So I would need to remove the fuel pump to get to the sender to clean I assume?
    We put £20 in yesterday and it said the tank was full - WINNER
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by AUDIESEL View Post
    Haha cool, cheers.
    In my experience cleaning won't fix it... its a carbon track that wears out so replacement is the only option... I changed the one on my A4 once... was about 30 quid from a dealer...
    <tuffty/>
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Cheers.
    is the pump unit easy enough to remove?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Fairly... search through Westy's build thread as he has done a pump swap on his S3... will be similar to what you need to do
    <tuffty/>
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    In case anyone else is reading this, I have taken the below from W3STY's progress thread (many thanks):
    Back seats out and service panel off:
    Fuel clips and electrical clip off:
    Top of pump off:
    Whole pump out. Staring into half a tank of V power
    Was starting to get a headache from the petrol fumes at this point but cracked on.
    Lovely new clean pump:
    Bottom part in:
    All done:
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    What's the best way to remove the two fuel lines at the top of the unit?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    In answer to this, there is a small concealed clip at the "front" of the fuel line where it meets up to the pump, push this in and twist gently, off it pops.
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    Looks exactly the same as my pump and sendor on my old focus, i mean exactly the same wow lol anyway if it is, it's pretty easy, just like mentioned tho the fumes will be overpowering leave doors open and if you smoke, dont! (like i did, then realised and slowley removed myself from the car, those were the days).
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Can I replace just the sender itself, leaving the original fuel pump?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Took the fuel pump out today and replaced the sender with a new part.
    Question.......should the float sit on the drivers side of the pump or the passenger side??
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by DALE_AVANT View Post
    Does anyone know the answer to this?
  1. I filled up with 'non-optimax' fuel..
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2004, 00:58
  2. fuel guage funkiness
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2004, 16:48
  3. Turbo add on for non turbo A4 1.8
    By imported_bearboy in forum Tuning
    Last Post: 9th September 2004, 14:18
  4. Air Filter for my A3 1.8 sport (non turbo)
    By imported_reda3lee in forum Tuning
    Last Post: 30th August 2004, 10:14
  5. Fuel guage problem
    By AndyCollins in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:05
