AH FabricationsBadger5
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    533
    Scraping noise after upright removal; driveshaft, bearing and hub replacement
    Hi guys,
    So, as some of you know I've been struggling with replacing my N/S front driveshaft, bearing and hub after I found my hub had taken a bash and was buckled. So, replaced everything, pressed in brand new bearing and hub and reassembled everything tonight. Took the car for a short test drive and noticed a very loud scraping noise from the corner I have been working on. It sounds most like the sound of the disc rubbing against the pads constantly and quite heavily. Tomorrow morning (because I can't be arsed to do it now) I will do some more investigative work, but I wanted to gather some opinions before I start to give myself a headstart.
    So, where do you boys think I should be looking / most likely causes for this during the reassembly? Things I may have not put on quite right etc.
    2 things I'm thinking.
    1) Because of the runout on the hub previously, the pads have worn all skewed and are therefor now hitting the disc on one of the high points. This I can test by switching the pads to the other side of the car? Any other thoughts?
    2) When fixing on the hub nut (get someone to press brake, torque to 190nm while still in the air, drop and turn another 90 degrees) when I was torquing up to 190nm in the air with someone pressing the brake, the brake would slip before I hit 190nm - suggesting maybe the pads are now not squeezing the disc evenly due to the previous runout? I had to put the car in gear to get to the required torque. Also when I dropped the car I could only physically get maybe another 45degrees of turn on the nut because my tools simply weren't big enough, am I gonna suffer for this later?
    Any thoughts are appreciated guys. Like I said, just wanna get a head start before I crack on tomorrow morning.
    On the bright side, the new components have fixed the previous problems ...just introduced this new one lol
    Thanks guys,
    Aran
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,304
    Could be something as simple as the brake shield touching the disk?
    I usually do the whole tightening sequence with the car on the ground for the hub nut, easier to stop it moving that way. If your going to do it with the car in the air, your probably better starting the engine, so you actually get full servo assistance.
    TD5 Land Rover Defender build
    Feb 2012
    Surrey
    533
    Hi aragorn. Yeah, someone else mentioned it might be the shield too, i'm gonna look tomorrow and fingers crossed it's something simple!!! Also, I did the torquing up to 190nm in the air, then dropped it for the last 90degree turn, it's what it told me in ELSAWIN so that's what I did lol
    Feb 2012
    Surrey
    533
    yeah, it was the disc shield lol
    Cheers Aragorn
  1. Part numbers request: Front wheel bearing and hub - thanks :)
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2012, 12:55
  2. Driveshaft and Hub removal attempted; stuck, help please :)
    Last Post: 10th August 2012, 09:22
  3. Scraping Noise from rear? Brake and pad replacement? or stone stuck?
    By parin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th June 2009, 19:29
  4. Noisy brakes - scrape noises.
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2004, 21:48
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
