Chris NottSky Insurance
    Mar 2009
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
    Hello, my wife just got "no result" on her driving exam, because the airbag indicator warning light came on the dash during the test. So after being relieved of the £62 test fee, I am kicking myself for knowing about this issue and not doing anything about it!
    Anyway, I am posting on the off chance someone experienced a similar issue to this and found a solution. The car is an A3 8L 2003 model.
    The main airbag warning light comes on on the tacho, usually when the car is started from cold. Once the car has been driven for a while and is switched off, upon switching it back on, the airbag warning light usually stays off, but not always.
    I've scanned the airbag controller using VCDS, which reveals the following fault:
    VCDS-Lite Version: Release 1.1
    Friday, 17 August 2012, 15:38:42:37423
    Control Module Part Number: 8L0 959 655 L
    Component and/or Version: Airbag Front+Seite 7008
    Software Coding: 01104
    Work Shop Code: WSC 06435
    VCID: 47E14A3076A3
    1 Fault Found:
    31-10 - Open or Short to Ground - Intermittent
    If I clear the fault, and restart the car, the faul immediately reappears.
    So, this is what I've done so far to try and sort this out:
    • chopped off the yellow connector under the passenger seat and re-wired directly (solder) as per this post
    • removed the passenger side warning light from the ceiling cabin light assembly, re-soldered joints and tested for loose connections
    By the way, the passenger airbag warning light looks like this (I can not find this replacement part 6350 1183C anywhere):
    I am pretty sure there is a bad connection somewhere between the airbag controller module and the lamp or the lamp module, but I am reluctant to pull anymore of the car apart in trying to sort this (minor) inconvenience out.
    Am I better off just sticking some electrical tape over the light and hope next time the DSA instructor doesn't query it?
    Cheers,
    -- ab1
    P.S. FYI: there is another post on the forum regarding this exact issue, but no solution.
    beachbuggy's Avatar
    Surrey
    1,745
    I'm almost sure you can unplugg the airbag and then code it out with vagcom there disabling the airbag,
    Mar 2009
    Quote Originally Posted by beachbuggy View Post
    I would love to know how to do that if anyone has any ideas..
    Mar 2009
    Fixed
    I "fixed" it by putting a 4K Ohm resistor across the passenger airbag deactivation warning light.
    -- ab1
  1. A8: Side Airbag Igniter; Passenger Side (N200)
    By A8D340TDI in forum A8/S8 forum
    Last Post: 31st July 2009, 22:24
  2. Dash Passenger Side Airbag/pocket section
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2009, 19:32
  3. A6 Passenger side airbag disablement????
    By griffthedog in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th February 2006, 11:10
  4. Passenger airbag deactivation
    By NOGAROS3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2004, 21:44
  5. Funny passenger side wing mirror.
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2003, 08:44
Tags for this Thread
