JMB RetrofitsAH Fabrications
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Haldex Pump Motor Replacement
    Hi,
    Just saw this while digging around ebay.
    Oem motor for haldex pre charge pump gen1 | eBay
    If your Haldex pump fails you can buy a replacement motor and potentially rebuild it.
    Has anyone done this?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    125 quid!?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    True, it is a little expensive for what it is, but if it's a pukka motor, then it's cheaper than a brand new Haldex pump and a second-hand pump is likely to go tits up too.
    Oct 2011
    760
    I have stripped my haldex pump and rebuilt it.
    Its very easy, only tricky bit is when strip the motor, the top flange has to go back a certain way.
    just take pics when dismantilling and you will be fine.
    its 145 with postage, still better than 400 from stealers
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    Did you replace the seals when you stripped it?
    If so where'd you get them from? Had the seals started failing?
    Liam
    Oct 2011
    760
    hi
    all your answers are here VWVortex.com - Haldex pre-charge pump removal / disassembly PIC HEAVY
    my pump was burnt out so i stripped it and rebuilt a few times to get the gist of it.
    i was going down the route of all new parts, guy on ebay used to sell refurbs, but in the end i just bought a second hand one.
    if you strip the motor you will see how easy it is to rebuild.
    the above thread tells you all about the seals
  1. Front wiper motor replace on A4 B6
    By Phil MC in forum General Technical / How To
    Last Post: 12th April 2011, 11:44
  2. Heater blower fan motor replacment
    By jamesfrain in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2011, 10:36
  3. wiring haedlamp washer pump motor
    By nick1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2006, 21:53
  4. Heater Motor Replacement
    By Greg83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2006, 10:53
  5. New A3 Wiper Motor Replaced, Is the wiper too high
    By Rolex1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2004, 20:37
