Badger5AH Fabrications
Results 1 to 8 of 8
    Jun 2012
    42
    help needed with my 2001 s3 ????
    Finding this site so helpful :O) Well after fixing a few problems with my s3 i have a strange one with my boost, :O( One day drive my car it reads 5.9 on vag.com next day it will read 8 or 9 psi few times it has gone upto 17 psi its all over the place and day by day different , most of the time 5.9 any ideas ????? the car has full samcos an arp remap and an arp r1 bov , newspeed induction kit
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Get the car scanned if you can and see if it brings up any fault codes, also have a look in the engine bay and see if there are any split pipes at all.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Guessing you are dipping in and out of limp mode or you have a big leak somewhere...
    Check all pipes under the inlet manifold for splits... be aware they may not be obvious either so pull them about a bit or see if you can get a smoke test done... they work real well ;P
    <tuffty/>
    Jun 2012
    42
    right after a random 1 o clock in the morning look with a torch found a pipe loose which conects to the underside of the back right boost hose sorted that but now another problem grrrrrrrrrrrrrrr
    Jun 2011
    Great Melton Norfolk
    1,349
    could be the arp bov causing it to overboost
    morgan306's Avatar
    May 2009
    Manston,Kent.
    144
    That video is private apparently Tufty!
    2002 Black S3 BAM, AmD remap,Badger5 3" TIP,JR filter & heatshield,Porsche 996 Brembos with 330mm disks,KW shocks & springs,RNSE+Bose.
    Jun 2012
    42
    new post up about new problem :O)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by morgan306 View Post
    Fixed
    <tuffty/>
  1. Help needed with door locking..
    By Ali A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2007, 17:55
  2. Help needed with car accident damage.....
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2005, 13:01
  3. Urgent help needed with value of sat nav plus
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 23rd November 2004, 17:07
  4. Help needed with S3
    By jeffreyyeung in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 13:17
  5. help needed with a mod!!
    By imported_Tariq in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 17:48
