Sky InsuranceAH Fabrications
Results 1 to 16 of 16
    Yohan87's Avatar
    May 2011
    404
    AFR Gauge (1.8T AMK)
    Afternoon,
    Just wondered whose running an AFR gauge and what make if they are?
    Heard good things about the AEM Wideband 02 UEGO Gauge. AEM Wideband O2 UEGO Gauge - Monitor Air/Fuel Ratio with the Digital 30-4100 - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
    The engine it would be going on is a 1.8T AMK (S3).
    I already have gauges for Oil Pressure, Oil Temp, Boost, and Voltage, but I've always wondered if I should have AFR as well.
    Does it just connect in where my existing lambda probe (already mapped out) goes?
    Is it a case of connecting the lambda probe up to the gauge and away you go or is there a separate controller required?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Have used AEM and VEMs gauges for AFR in the past on customer cars... VEMs has an EGT probe too which is useful...
    How do you mean your lambda is mapped out? I assume you mean the post CAT one?
    Normally they should go near the turbo outlet so normally weld a boss next to or close to the existing pre-cat lambda
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    An EGT probe would be useful as well, can they both be shown on the same VEM gauge? Any links to said gauge?
    Yes that's what I meant, I'm running a de-cat and so the post CAT lambda sensor has been mapped out.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    VEMS Shop
    VEMS Wideband & EGT Gauge User Guide
    Wideband lambda probe should be as close to where the std one is as poss really...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    Cheers tuffty.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    i got the AEM UEGO.
    i've got the 3"DP/de cat. as mine has the AGU limp only have 1 lambda so i had a spare hole for it.
    just a case of just the sensor in and run the wiring up to the gauge. and then a live feed and earth wire
    nice easy job
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    add a second boss close the the main lambda for accurate readings... too far away and it will be more sluggish responding
    VEMs egt is an option, and is handy for 2 gauges in one
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Yohan87's Avatar
    May 2011
    404
    Thanks guys.
    Had a chat with Nick@R-Tech last night and he offered another suggestion - Innovate Motorsports MTS Modular Tuning System
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Humm... I know Bill has seen issues with the Innovate controllers...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    404
    I see.
    This is the idea behind my original post, get all these experiences together
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    Innovate LC wideband and their having to remove to do air calibrations put me off... that and the poxy thing was unreliable..
    Used AEM been very good, VEMs also been ok.. and dual gauge has its appeal
    bill@badger5.co.uk
    Yohan87's Avatar
    May 2011
    404
    Bill can you supply the AEM afr kits? If so can you PM me an all in price please?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    replied
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,759
    I have an innovate MX or something like in my S3...
    It realy doesnt like it when the injectors shut off on over run.
    It forever throws an error code . on track or fast driving its fine. just eco driving it throws up errors.
    I also have an LC1 in my mk2 which is fine. Wierd.
    Noggy Blue 2001 S3
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    your glitchs with innovate match my dislike of them
    bill@badger5.co.uk
    Yohan87's Avatar
    May 2011
    404
    Sounds like AEM UEGO is the way to go
  1. which gauges? boost, water temp/ oil temp/psi, AFR?
    By boost-addict in forum General Automotive Chat
    Last Post: 1st June 2012, 08:33
  2. A strange question regarding my AFR gauge and lambda probe...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2011, 18:39
  3. Finaly fitted my wideband AFR gauge...
    Last Post: 7th October 2011, 17:16
  4. Fitting a boost and afr gauges...
    Last Post: 19th May 2009, 22:29
  5. A Wide band sensor and an AFR gauge in an S3?
    Last Post: 4th October 2008, 11:45
