Badger5Sky Insurance
Results 1 to 8 of 8
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Still no joy with coolant :((
    Afternoon guys
    Since speaking to a few of you guys about what to look for or check with my lose
    Of coolant ive had a head test done on the car and that came back fine. Still cant find no
    Split hoses and also changed coolant bottle cap as thought it might be knackered.
    BUT
    Still losing coolant and now costing me alot having to go to audi for g12 all the time.
    Is there anything else i can check had it on vcds and no faults appered so now getting to
    The point of being lost with it.
    Thanks for the advice guys
    Grant
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    If its losing a serious amount then it should be blantantly obvious. there will be reddy/pink crust around whereever its leaking from.
    You also dont need to goto audi for G12, you can buy the correct stuff from your local motorfactors or halfords.
    Drive the car until its upto temperature, then park up leaving the engine running, get the bonnet open and have a good look around. Remove the undertray if it has one fitted, so you can see whats going on.
    TD5 Land Rover Defender build
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You have checked inside the car i take it?...
    future's Avatar
    Scuderia Vittoria Edition 001
    Sep 2009
    Bournemouth
    363
    the normal leak areas are the thermostat housing and the block connection on the right of the engine. Have you checked your bleed valve is fully closed?
    Audi S3
    ''If a hammer doesn't fit it. it's technical''
    AH Fabrications catch can for sale £50 posted!
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Is there a pressure release valve in the coolant cap? If that were releasing at a lower pressure - could it be venting as steam? (it's just an idea I'm throwing out there - I'd still expect residue!)
    Can you get UV dye to put in the coolant that might help track it down.
    +1 to checking the drain tap on the bottom of the rad is fully done up.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Snash7's Avatar
    May 2012
    Horley surrey
    84
    Thank you all guys for your input.
    I am new to all this so still finding my feet.
    As you said i thought it would be easy to spot as the g12 is bright pink but havent had much luck
    Finding any drips or pinkish stains.
    @future - how would i check if the bleed valve is open.
    Does anyone know of a audi specIalist around the gatwick area
    Thanks for all the helpfull replys
    Grant
    Feb 2012
    68
    If its not dripping out the bottom, then the only other places it could be going are into the oil (check the colour) or your burning it in the cylinders........
    Three things to check: 1. Oil - is it milky. 2. Exhaust, does it smell of coolant ? 3. Compression test.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by lloydie1 View Post
    As said in post #3
    4. Check in the car right under the footwells, it could be the heater matrix...
  1. Problem with coolant level!
    By Isoniazid in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th January 2010, 07:18
  2. Intermittent fault with coolant and engine management system
    By clarebear in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2009, 15:45
  3. Still need polish with Megs Cleaner wax?
    By ~RS~ in forum Detailing
    Last Post: 18th May 2009, 11:41
  4. Is there still a problem with my s3
    By peakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2009, 09:42
  5. Anybody had joy with the sticky carbon fibre?
    By Oranoco in forum General Chat
    Last Post: 22nd August 2008, 12:16
