Badger5Sky Insurance
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    New to VCDS - 1st Log Attached
    Morning all,
    Having just received my Gendan cable, I've downloaded VCDS Lite (just paid $99 for the full version and waiting activation) and went for a quick run.
    Now obviously only running on the 'lite' software, ports to log are limited.
    I logged port #1, 2 & 3 and here are the results:
    All look ok? Car is meant to be 270bhp (AMD remap with printout), but I'm not too sure, doesn't feel 270bhp...
    Once Ross-Tech have activated my software, which ports should I be logging to make sure the car is performing as it should?
    Cheers in advance,
    Ryan
    '02 Audi S3 - 270bhp / 283lb ft - SOLD
    '08 BMW 135i - 306bhp / 295lb ft
    '12 VW Golf GTD 170 - 168bhp / 258lb ft
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Airflow suggests 267 ish hp but of course this doesn't always mean it is doing that... is pulling fuel (block 001, Lambda Controller %) under boost which suggests a boost leak somewhere...
    Here is a list of all the engine blocks...
    http://www.ross-tech.com/vag-com/m_blocks/
    <tuffty/>
    Ryan_W's Avatar
    Mar 2010
    Stamford
    332
    Cheers buddy...
    Oh the joys of boost leaks! Guess I'll just have to buy some silicone hosing and replace the lot. Isn't the one under the inlet mani normally a prime culprit? What size hosing (ID) do I need to replace the lot?
  1. VCDS data logging
    By jonboi_h in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th February 2010, 13:22
  2. New S-Line, 1st impressions
    By cosmicblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2005, 01:03
  3. New Noggy on the block- 1st drive
    By trekbiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2004, 09:56
  4. First post for new S4 owner 1st Wax with Zaino
    By jwh2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 08:18
  5. New guy in the States with my 1st Audi
    By gcthree in forum The Welcome Section
    Last Post: 29th October 2003, 23:02
