mcpickering
Hi guys, i did put this in the existing Door blade thread, but have had no response (because it is on the second page and most people wont read that far) so here goes:
I had a nightmare with this yesterday
my drivers side blade was pretty much hanging off, so i thought i'd give it a go taking it off.
straight from the off, i WD40'd all of the screws in hope it would help, only one screw actually came out, the other three were stuck (it seems that someone had attempted this before as well, 2 of the screw in points on the blade had rounded off and come away from the white plastic bit in the blade itself and there was a random long screw going through the door straight into the blade, which was also too long and poking through the outside of the blade). i eventually managed to get the blade off the door but the white plastic bit was in pieces and not even attached to the door blade
i was then left with the prospect of somehow removing the screws from the door as they are just hanging loosely, i managed to eventually get 2 of them off, but i'm now left with one screw still in situ and some duct taped holes to stop water ingress.
i don't really know what to do
i guess it's a case of buying a new blade (the passengers side is almost as bad so i may as well get both) i take it you can't buy a replacement white plastic insert?
James
James
