Results 1 to 13 of 13
    Aug 2010
    bradford
    1,239
    head bolt tool and timming belt tool
    can anyone post a link of the correct head bolt tool and the timming belt tool to slaken it off the timming belt please iv look on ebay but i just dont no wich one is right and dont want to buy the wrong one thanks.
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    beachbuggy's Avatar
    Surrey
    1,727
    Ribe 10 splined socket for head bolts
    VW AUDI CYLINDER HEAD SOCKET TOOL KOKEN ST4027-140 | eBay
    No such thing as a timing belt tool. I've got a cut down 8mm Allen key to get pulley off, then belt comes off
    Aug 2010
    bradford
    1,239
    or thanks mate and just got told they was a tool the slaken it off thats all never mind
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,043
    I assume this is to replace your current head with the large port one you have? If you are using a new belt (advisable) then just cut the old one...
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Aug 2010
    bradford
    1,239
    thanks tuffty ill just cut it then and take it i wont need the tool or will i need it to get the new one on by slackening.
    thanks for the editing tuffty forgot how to post pic lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,043
    You will need the tool Andrew posted a link to... thats so you can re-compress the tensioner damper... ideally you need the pin that normally comes with a new damper or... I would be personally changing the damper if you haven't had it changed that you are aware of...
    They don't typically get changed as part of a cam belt change as for some reason Audi deem it unnecessary... however... the dampers have a habit of getting tired and will loose tension causing the cam belt to slip teeth and of course nuke the engine as a worse case...
    Considering the level of work you are about to under take I would buy a new one...
    <tuffty/>
    Aug 2010
    bradford
    1,239
    Ok I'll get the tool ordered tuffty.
    Dampers where's best place mate that don't cost a tone
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,043
    Quote Originally Posted by s3gazz View Post
    I got mine from GSF... my last one was an OEM one with the logo's machined off... still £40ish though...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    Ive got both tools numb knackers ......
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by Andrew@A.L.D View Post
    N
    Never knew that tool existed, learnt something .
    I use my brake calliper rewind tool in reverse. Fits over and then winds in to compress the damper . I guess it's a solution if any one doesn't have that specific tool. It also works when the tensioner is still installed on the car. Put it between the tensioner end and camshaft pulley and gently wind it out will compress the damper enough to get pin back in. Again just a tip, saves trying to get the thing out.
    Jun 2009
    Leeds
    3,353
    You can make you own with a longish M5 bolt with nut and a large but thick washer, Its hard to reach so i have a 8mm spanner thats been bent at a 90 deg to get to it when its in and wound down
    FOR SALE
    Aug 2010
    bradford
    1,239
    thanks guys great help.
    dave ya a star mate thanks.
    tuffty ill ring gfs and get the part ordered then just a damper.
  1. What tools and toolbox??
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2010, 20:12
  2. 1.8 Cylinder head bolts removal tool
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th July 2010, 10:59
  3. Timing Belt Tools
    By aragorn in forum A8/S8 forum
    Last Post: 16th March 2010, 06:14
  4. crankshaft seal tools and experience
    By kninio in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2007, 10:14
  5. v6 12v timing belt tools any body?
    Last Post: 5th July 2007, 18:52
