AH FabricationsChris Nott
Results 1 to 15 of 15
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    LCR Brembo on S3 with 18 RSTT Alloys - Spacers?
    Darn! After visiting my local scrappy, I seem to have come away with a set of LCR Brembo, carriers, discs and pads!
    Lines were shot, so i've ordered a set of lines from Bill.
    Now my S3 has 18" RSTT wheels (Assuming genuine as ETKA says it was a factory option for my VIN) will I need spacers?
    10mm front, 15mm back? Anyone with this setup notice if they rub when fully loaded?
    Any brand recommendation? Don't fancy going budget on such a crucial component!
    Dave
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    I'm about 99% sure you wont require spacers. I have run 17" S3 wheels and TT wheels over my brembos and there's loads of room so I'd expect the RSTTs to be fine.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    18'' RSTT's definitely require spacers with brembos, I believe Jojo said 10mm was required.
    Std S3 wheels have LOADS of brake room, RSTT's don't have so much.
    Westy's Avatar
    Dec 2008
    17,280
    I give up, I really should stop posting unless 100% sure
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    My AP's that are a little wider than Brembos 'just' missed on Avus's with no spacers... had to use spacers on my RSTT's though..
    <tuffty/>
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    I Did do a little reading, and i'd rather err on the side of caution and get spacers.
    H&R hubcentric seem ok? Any options on rubbing / handling on 10mm fronts, 15mm rears?
    Cheers for the help
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    I have 15mm eibach on the rear and 10mm hubcentrics (from ebay but good quality ones) on the front... no rubbing lowered at 30mm
    <tuffty/>
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    You will definately need spacers I'll measure up when I get home as I fitted mine last week, I'll get a better pic too
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Yup, 10mm spacers for RSTTs, the inside of the spoke catches, near the centre of the rim. No issues with OEM 17" Avus rims, as the spokes are flat.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Ok just had a quick measure up and with 11mm front spacers there is just under 8mm clearance
    Therefore a 3mm spacer will be dead tight (touching). Make of that what you like
    2002 S3 REVO
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Minimum 5mm for clearance then!
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Yeah I recon so But I wouldn't fancy only having 2mm clearance
    2002 S3 REVO
    Flubster's Avatar
    Tinkerer
    Apr 2012
    Suffolk
    36
    Well i've finally got round to fitting the Brembo's. Once I finally got the system bled correctly (God those master cylinder nipples are a nightmare!) all is good.
    I had a set of FK 8mm spacers which I used (FK013 08) which vibrate like a good'ern over 60. I've made sure the mating is clean, and torqued up when wheel is off the ground and in the "star" formation.
    Does anyone have suggestions on a good set of spacers around 10mm that people have experience on being ok? I assume most 10mm spacers don't have the wheel side spiggot ring which I think is the problem as the 8mm FK don't.
    These are geniune RSTT's btw.
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Forge 11mm spacers are hub centric... the 10mm ones I bought from eBay (don't think the seller exists any more sorry) are hub centric too..
    Forge ones are as good as any... you may well need to change the bolts for a tad longer (assuming you already are using longer ones rather than the OEM ones)
    <tuffty/>
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    I was lucky and got a full set of spacers off the classifieds on here nice and cheap but otherwise i was gonna go for these as they seem a good deal for the price
    12mm Hubcentric Spacers CreationsMotorsport
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  1. Any pics of s3 8l with rstt replicas and 10 or 15 mm spacers??
    By S3 rpm in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2012, 09:02
  2. GENUINE RSTT ALLOYS WITH BRAND NEW NANKANG TYRES
    By N4THW in forum For Sale/Wanted - Audi Parts
    Last Post: 7th February 2012, 18:37
  3. S3 wheel spacer with RSTT wheels
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2009, 22:27
  4. Need advice TT '04 with RSTT 18"
    By imported_banshe in forum TT/TT-S/TT-RS Forum
    Last Post: 17th August 2004, 21:09
