Volks AutosAH Fabrications
Results 1 to 13 of 13
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Question PCV delete w/o catch can for now - all ok?
    Got a couple of leaks in my PCV system, until I get a catch can on my S3 BAM can I route the brake boost pipe just to the intake manifold like tuffty? Can I then block off the other vac pipe in the manifold and just connect the oil filter pipe to the triple joint on rocker cover that then links to the "hockey put valve" then to the tip? Thanks! Wanted to get round to doing this today if possible until I get my catch can ordered.
    Vex182's Avatar
    Apr 2012
    Hinckley
    878
    Anyone able to give some advice? I can't see why this won't work after reading the sticky about catch cans.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    You can run a PCV delete without a catch can... this is what I am doing currently..
    I detailed a PCV delete/catch can fitting in a previous thread...
    All you need to do in your current case is remove the rubber T piece with the PVC valve in from the outlet in the block and join the outlet to the hard pipe (crappy plastic bit that breaks) going to the triple pipe jobber..
    Block the vac outlet underneath the inlet mani and connect the servo vac to the 90 degree outlet on the end of the mani... simples
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    878
    Yeh that's what I thought, the "hard pipe" do you mean the big one above the oil filter, if you do then it is as straight forwards it sounds!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    I think I need to make this pic my avatar lol
    The 'T' I mean is PN 06A 103 247 in the pic... remove that, remove all teh rest of the above too... join from 06A 103 213 F to the pipe going up to the triple hose... block off the outlet on the inlet mani where 06A 133 783 AS was connected and connect the servo vac hose removed from red circled piece bottom left of the pic to the 90 deg outlet on the side of the inlet
    Simples... AMK/BAM s3's are dead easy to PCV delete
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    878
    Yeh that's what I have just done, just seems like a lot has come out lol. Just going to go for a quick test before putting the covers on snd getting breakfast! Because I had a leak in this piping, I guess I should hold boost a little better now?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    Quote Originally Posted by Vex182 View Post
    ...Because I had a leak in this piping, I guess I should hold boost a little better now?
    I would imagine so... not having a leak is a plus
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    878
    Seems all good! Nothing appers to be leaking, e.g oil deposits etc. All pipes seem tight and I have brakes lol. Cheers.
    Freeman_1986's Avatar
    May 2013
    Forest Of Dean
    Would a catch can have to be fitted at some point? or would just doing this suffice? Would doing it without damage the engine in any way?
    S3 AMK (AKA FUTURE CLASSIC )
    Mods So Far: PCV Delete, N249 Bypass, S2K Filter, Black Side Indicators, FMIC, B5 TIP, Rear Anti Roll Bar, Polybush Upgrade.
    Mods Wanted/Planned: Wheel Spacers, Moar Silicone, 3" Downpipe, Decat, Debadge Rear Rings, Spray Front Rings, 8P/V Gear Knob, REVO!!!!!!!
    MISC: Sort Out Paintwork...
    Because It Makes No Attempt To Be Great, It Is Therefore Extremely Great.
    Vex182's Avatar
    Apr 2012
    Hinckley
    878
    Mine is still like this now! Kinda just left it and all has been well.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    May 2013
    Forest Of Dean
    I'm assuming it has all the same benefits of doing it with the catch can then? Only ask as I have a leak on the PCV system.
    May 2013
    Forest Of Dean
    Also am I going to need any extra hose? What size etc?
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Does the same go for A3 8L 1.8T FWD? I assume so....just checking...
    edit: Guide - How to fit a catch can and simplify the PCV system
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  1. Replies: 596
    Last Post: 5th May 2014, 20:26
  2. AH Fabrications catch can for sale
    By future in forum For Sale/Wanted - Audi Parts
    Last Post: 5th July 2012, 00:18
  3. For those that have fitted catch cans
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2010, 12:20
  4. Reason for deleting pcv valve and pipework with catch can.
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2010, 21:05
