JMB RetrofitsVolks Autos
    Jan 2012
    21
    Who here is successfully running a forge split-r with no error codes on their AUM?
    I'm not interested in another thread about the 007p being a better performance part or the car being intended for a recirc. rather than an atmos. I'm just interested to know whether the forge split-r can actually be run on an AUM without causing ECU errors/ running issues and at which hybrid setting this is possible on?
    Thanks in advance for all helpful replies.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    IMO No...
    Its no good as an atmos or a DV valve as its hugely compromised to make it what it is...
    While you may not be interested in the whole "the car being intended for a recirc. rather than an atmos" discussion the fatcs are on std management they will cause problems...
    There is no compelling reason to use the split-r over a recirc valve...
    <tuffty/>
    Yohan87's Avatar
    May 2011
    405
    If the noise is what you are after, then you will easily achieve that with a Forge 007/008 valve and an open cone filter.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I'll hold my hands up and admit I ran a Split R on my first S3 for about 6 months and also my current one (APY) for over 9 months.......
    It didn't throw up the engine management light on either of the cars.
    My 1st S3 only had the Split R on..
    Whilst my current car S3 is running a B5 TIP, Large Cone filter, Re-map and 007P and I would say my current set up is now louder than how it was on my 1st S3 that was standard with just the Split R
  1. Forge Split R (Splitter) DV Fitting Help Needed Please!
    By AudiS3Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 07:00
  2. 1.8T Sport Boost/vacuum with forge split-r
    By alex-qts in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th April 2009, 18:37
  3. Forge Split-R Recirc Valve... need a bit of help!
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2008, 18:55
  4. Who here has a degree?
    By silver75 in forum General Chat
    Last Post: 26th May 2007, 18:43
  5. Who here has an upgraded turbo?
    By k0mpresd in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2004, 04:43
