JMB RetrofitsAH Fabrications
Results 1 to 27 of 27
Thread: Dog bone mount
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Dog bone mount
    Hi,
    I had problems with tracking etc not getting the car to pull in a straight line, keeps pulling left, at thw weekend I fitted my silicone tip and whilst under the car I thought I would give the dog bone mount a tap with my hand, there was a metal on metal sounds, so I take it that it needs replacing but could this also be was is causing the car to pull left and give it a few handling probs? I am still trying to understand these cars and needing all the advice I can get before having to take to an Audi garage .
    Thanks Simon
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    Not likely, you'll feel a nakered dogbone when you change gear, it'll knock.
    Pulling left/right is likely your rod ends or top mounts, but could be other things, like tyres or shocks etc.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    As above, it won't affect handling at all, but will make your gear changes feel sloppy and it'll knock when you do so. It needs changing so replace it with a poly bush, you may as well and you'll never need to change it again. Don't fit the yellow one though, fit the red one from the A3/Mk4 Golf Diesel It's a bit softer so you don't get more vibration, but it'll feel like a new car, they really are awesome.
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Jun 2012
    Redhill Surrey
    635
    I do get a knocking noise sounds like its coming from under the car around the gear stick area, I changed the top mounts, tbh I do think one of my shocks is knackered, as when I jack the car up one of the shocks drops lower down than the other, is the dog bone mount easy to change yourself?
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by Grale1 View Post
    Absolute piece of urine to change mate, it's not the engine mount you change, it's the rubbers that you change. When the rubbers get old, you MAY have to burn the old ones out with acetylene or a blow torch, but the new poly ones go in with easily with the supplied grease.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    1 x Front Engine Mount Dog Bone Diesel PFF85-420R Powerflex Poly Bush Bushings | eBay
    This is the one I bought. It's the red bits that you change for those who don't know, standard ones will be black and very perished though...
    Jun 2012
    Redhill Surrey
    635
    I was looking at getting the red one the other day, when the car is on the axl stands do I need to support the engine with a trolley jack or anything when I un screw the mount or is it ok to undo and take off with out anything supporting them?
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    The key to changing a dog bone mount and ensuring it doesn't vibrate is to not tighten it up more than it should be, if you tighten them up too much then you will preload the bush and it won't offer the same damping characteristics as what it was designed for and you will get the vibration that so many people complain about.
    But as said above, it's a really easy job to do and well worth doing for the sake of £15.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    No it's fine to take off without support, all it's for is latteral (front to rear) movement of your engine, it has 3 mounts, the two engine mounts that mount the engine to the chassis, and one dog bone to stop it rocking. So you'll be fine
    VW GOLF MK4 GTI 2.0 8v LOWER ENGINE MOUNT DOG BONE 1JO 199 851 FROM LOW MILE CAR | eBay
    Have a look at the picture there, that's what it looks like and you can see where it bolts on, was easer than trying to explain it lol
    Jun 2012
    Redhill Surrey
    635
    Ok well I might as well get one, where is the best place to get them from? I've only seen them on eBay
    Jun 2012
    Redhill Surrey
    635
    Cheers benjiman, I'll be ordering one tonight and hopefully it'll come for the weekend Chen I can put on some of the other goodies
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    got mine from Awesome GTi
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Well that link I showed you was the one I got and is the cheapest on the net IIRC...
    It'll only be pence if it is any different anyway
    Ben
    Jun 2012
    Redhill Surrey
    635
    Just bought the red one thanks benjiman. Hope it helps with the knocking I can hear
    Jun 2012
    Essex
    210
    Soo easy to change, done mine the other week. I fitted the yellow one and honestly isn't as bad as what people make it to be.
    Sep 2006
    Sunny Suffolk
    552
    Do you need a torque wrench to fit?
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Little towards the pulling left and not driven straight i had that little when i first brought my motor and it was a seized caliper on the rear might be worth checking.
    Steveo_A3_1.8t's Avatar
    Mar 2009
    Great Wakering, Southend
    196
    Quote Originally Posted by Munch View Post
    im a yellow man two lol!! ive got no complaints, you know you havnt got a sloppy rubber bush but its not as bad as people make out IMO
    steve
    "Oh shut up you tart!"
    Sep 2011
    Isle of Man
    175
    +1 for yellow I haven't noticed any increase in vibration think it is all down to getting the torque correct.
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    Quote Originally Posted by Hammy999 View Post
    Its all about that!!
    Jun 2012
    Redhill Surrey
    635
    I got a red one coming this week, tbh I think the vibration issue is a bit erelivent when the cars have been lowered as you feel very bloody bump in the roads that got right through the car, but this is my ipinion.
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    The vibration people talk about is on idle revs, some people have had it so bad it rattles the dash and steering wheel whilst sitting at traffic lights. Its fecking horrible if you experience it actually, it's like sitting in an old diesel Transit van.
    Mar 2009
    196
    Quote Originally Posted by beanoir View Post
    lol! i bet you can make a nice pinacolater on the dash thou!! i wish my audi was a reliable as an old transit thou
    Sep 2006
    Sunny Suffolk
    552
    Quote Originally Posted by vanilla_ice View Post
    beanoir's Avatar
    Jan 2007
    51 Degrees North
    2,173
    You don't need one, but it helps!
  28. #27
    Jun 2012
    Redhill Surrey
    635
    Just fitted the red one this afternoon, very easy to do, hope now that the knocking will go
  1. Front Engine Mount (Dog-bone mount)
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2006, 15:45
  2. Dog bone mount
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2005, 22:50
  3. Dog Bone Mount and Porsche Cayenne S brakes
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2005, 20:55
  4. Powerflex dog bone mount and low speed Judder?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2005, 15:59
  5. R32 Transmission Dog Bone Mount
    By richy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2005, 14:53
