JMB RetrofitsChris Nott
Results 1 to 8 of 8
    deana4's Avatar
    Jan 2011
    county durham
    29
    Anyone changed a map sensor?
    Scanned my car again and it's come up with map sensor and will not clear the code. Hopefully problem solved.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,545
    What code? MAP sensor is not one that I have ever seen go wrong
    <tuffty/>
    deana4's Avatar
    Jan 2011
    county durham
    29
    <tuffty/>
    Po237
    deana4's Avatar
    Jan 2011
    county durham
    29
    Also had
    p1296 which is thermostat(I know I need this doing)
    P1355 cylinder 1 open circuit
    p0106 manifold/barometric pressure sensor
    p1297 pressure drop between throttle and turbo
    p1570....can't remember this one but nothing much
    So a few lol..... Need to get it sorted
    only one that won't clear is the map sensor one p0237
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,347
    check the wiring plug on the sensor first, might not be connected properly!
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,545
    Guessing you have a handheld scanner rather than VCDS hence the P codes...
    17704/P1296/004758 - Ross-Tech Wiki
    17763/P1355 - Ross-Tech Wiki
    16490/P0106/000262 - Ross-Tech Wiki
    17705/P1297/004759 - Ross-Tech Wiki
    17978/P1570/005488 - Ross-Tech Wiki
    16711/P0327 - Ross-Tech Wiki
    My guess is you have a wiring fault possibly a bad earth or something as there seems one too many electrical faults for it just to be a faulty sensor... in my experience multiple electrical issues are generally down to wiring...
    Check the earths under the battery tray...
    <tuffty/>
    deana4's Avatar
    Jan 2011
    county durham
    29
    <tuffty/>
    Using vcds....gives both codes but I always use the p codes for some reason.
    I know the coil pack wiring has been messed about with by previous owner as its all taped up so need to give that a good check.
    Ill have a look under battery tray at the earths when I get a chance next. Map sensor in a tricky place to check connections was gonna disconnect it and make sure it's got a good connection before ordering a new one
    deana4's Avatar
    Jan 2011
    county durham
    29
    Had the battery out tonight gave all the earths a good clean up had slight corrosion on them. Now I have lost the borking when you rev it on idle which is a bonus. Now all is left is when driving put your fit down and it hesitates a few seconds then boost will come on. Not had chance to resan the car tonight but will do it tomorrow see what I'm getting now.
  1. anyone got a spare s3 map sensor pipe
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2010, 21:56
  2. Anyone changed a temp sensor on a 1.9 tdi?
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2010, 18:35
  3. MAP sensor or MAF sensor
    By imported_stanA3turbo in forum Tuning
    Last Post: 17th August 2004, 23:09
  4. Replies: 1
    Last Post: 16th May 2004, 11:04
  5. Anyone changed the rear speakers in a Bose TTR?
    By clived in forum In-Car Entertainment
    Last Post: 17th April 2003, 23:38
