Results 1 to 38 of 38
Like Tree1Likes
  • 1 Post By Scullies
Thread: Techincal question for any Haldex controller "experts"
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I have opened up a haldex controller unit, to see how it all works. Simple mechanics controlled by a circuit which gets info from ecu.
    Below is 3 pictures of the pin that restricts the flow of the haldex oil.
    picture below with the oil flow fully open - No haldex operation.
    Next is pin half way. Now for the 1st question.
    With the pin in this position, is the haldex on approximately 70/30 power split?
    Lastly, the pin is fully closed.
    This would stop all oil flow and increase pressure on haldex. In this position is the haldex on a 50/50 power split?
    Working on some top secret stuff here
    Whopper likes this.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    I e never seen anyone open up a haldex controller before so you might struggle for an answer from us lot.
    It's good to see new things.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Oct 2011
    760
    interesting stuff, is that the controller or the haldex diff?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Heres another picture of the inside. I have removed the wiring harness though.
    That pin is part of the haldex controller.
    Oct 2011
    760
    ive read of people try to hack the haldex controller to no avail.
    So if you manage it, you could become a very rich man.
    and i could be your uk outlet my new best friend buddy pal mate -)
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    That is the idea, waiting for some components to be delivered then get programming.
    In theory it should work, time will tell
    May 2011
    Sunny South wales
    82
    I thought the haldex works like a hydraulic wet clutch/ brake setup, found on many bikes and plant, and the ayc system on evo's, so
    min oil pressure to the clutch plates would be disengaged (no lockup)
    max oil pressure to the clutch plates would be locked (50/50 power split)
    so when the pin is fully closed, there would be no oil pressure (disengaged) and fully open would be max oil pressure ( locked), also does the solenoid that controls the pin, works on pulses ( duty cycle) rather than as a normal valve restricting oil flow ?
    Am I on the right path with my thoughts, or looking at it the wrong way ????
    jamie408's Avatar
    Aug 2011
    stoke on trent
    29
    id of said the pin is open and you get 50/50 too.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    this should help you with any questions you have:
    http://www.billswebspace.com/HALDEX.pdf
    page 30 is possibly the reason alot of controller fail.
    page 32 answers your question
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Thanks Karl,
    I have already looked at the haldex pdf. It doesn't say if "max pressure" is 50/50 split or OEM split.
    What I'm not sure about is, if the OEM haldex controller pushes the pin to the fully closed position or not.
    My thinking is that the OEM haldex controller never uses the "max pressure" setting, maybe it only closes a little to apply the max OEM power split.
    - Darren
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,502
    On page 31
    Regulator Closed:
    Maximum pressure on clutch
    plates.
    Regulator Partially Open:
    Reduced pressure on clutch
    plates.
    Regulator Fully Open:
    No pressure on clutch plates.
    This suggests to me that the OP is correct with his assumptions on how it works in the first post!
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Some more info to help others understand
    No assumptions here
    Aug 2009
    Costa del Cardiff
    535
    Interesting, credit to you, seem to know your stuff. What is it you are trying to ahceive? Constant 50/50 split or just an even distrubution when the haldex is activated?One question though, is it a realstic option? Would this stress any other componants or would you run the risk of any damage running 50/50 split constant?
    Wish list; Milltek Cat back non-res exhuast, R32 roll bar, adjustable rear tie-arms, Powerflex polybush dog bone mount, XS Power Manifold, 3"DP, B5 TIP V2, & a Remap :D
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    My plan is to program a small circuit board to control the ORIGINAL haldex controller from a dash mount switch, I should be able to set the power split to any ratio, be it fully adjustale from 100/0 through to 50/50. Or have specific setups like, fwd (100/0), race (65/35) or drag (50/50). The exact split will be difficult to measure as the pin only moves a tiny bit when adjusted.
    The OEM haldex has an oil temp sensor that cuts out the haldex operation when the oil reaches 100 degrees to protect the clutch plates, but continued driving with the haldex in any activated position is going reduce clutch plate and oil life.
    Once I get the actual control part working, I will need to look into using the temp sensor to cut the haldex operation or at least alert the driver the haldex oil temp is high.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    because the car doesnt have a centre diff, its not a great idea having constant 50/50 split i dont think, there still needs to be some change in drive from front to rear.
    i think scullies right tho with his annotated pics above
    Westy's Avatar
    Dec 2008
    17,273
    I like the idea behind all this but I don't really see the point in interfering with the Haldex as it already does a good enough job! Dump the clutch at 5k on the drag strip and it just goes.
    S3 Build Thread
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Also, I heard that 50/50 is like diff lock on a 4X4. You can't do tight turns with it engaged as it will stress the gearbox and cause damage.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Quote Originally Posted by Scullies View Post
    good shout, yeh it will need SOME slip
    to add, incase people dont know, front wheels spin faster than the rear in a car without a centre diff.
    perhaps this is the reason for the common dragging issue, and the haldex isnt allowing any slip for the turn
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Well, firstly it would be an upgrade for those who want to and SECONDLY, (the reason I need it) would be a cheap option to get a non responsive/damaged haldex controller working again but in a manual way.
    Westy's Avatar
    Dec 2008
    17,273
    I like the 2nd one
    S3 Build Thread
    Jun 2011
    S.E. Melbourne/ Australia
    146
    I did dismantle one of those 5 months ago to look at the inner working of it.
    If you know your way around electronic circuitry you can controll the stepper motor that drives the needle remotely, unfortunately i'm not very good at electronic stuff.
    Theres a company that makes a manual haldex controller called SQS, but you need to get under the car to adjust it.
    Then there's the hadex competition that keeps the power split to 50/50 all the time but some people reported some rear wheels hopping at low speed.
    And yes needle fully in gives you 50/50 power split.
    2000 Brilliant Black TT Quattro.
    2010 Daytona Grey TTRS.
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    how about enabling 4x4 when braking? that way you have you engine braking traction applied to all 4 wheels instead of just the front?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by Rosso TT View Post
    Yeh, seen the SQS controller. That's what has put a bee in my bonnet about sorting a controller from the dash.
    Rear wheel hopping is very bad. When you turn in normal fwd only, your outside rear wheel moves faster than your inside rear wheel. So when you on 50/50 split, (to my knowledge the rear diff is locked, meaning both wheels turn at the same speed. At least this is what diff lock does on an off-road 4X4 vehicle) the rear diff is trying to turn both wheels at the same speed, but one wheel turns faster than the other causing the other wheel to skip. Now imagine how much torque is being applied to that wheel to allow it to skip over the solid tarmac. Something is going to bend/break. Driving like this is snow, sand or mud is ok as the wheels will be slipping while they try grip the surface.
    Alex C
    If I can get this to work the haldex will not disengage unless you select FWD or it trips with overheat alarm (design dependent)
    So you will have haldex braking and haldex when in a corner and not on the throttle.
    Colly's Avatar
    The Tangerine Machine
    Jan 2012
    Isle of Man
    277
    im really intrigued as to if this works as id love to do summit with mine
    Sold 03 S3 Audi Exclusive Papaya Orange,
    New Car 05 Evo VIII FQ 340 MR 415bhp 400ftlbs
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    Doesnt the haldex have a open diff in it like the front to enable both rear wheels to rotate at different speeds. I can see the problem of the wheel speed front to back but not side to side. Or have i got it wrong?
    Hope it works for you as i would be interested in something like this.
    2003 S3 BAM 225 Dolphin grey, Silk Nappa Leather, Bose, Cruise control.
    Mods; custom code stage 1, S3 8P gear knob, pipercross panel filter, APR diverter valve, Forge TIP, Powerflex bushes, R32 rear anti roll bar, spacers F 15mm R 20mm, haldex race controller, Bilstein b12 pro kit, Porsche 996 turbo brakes.
    Alex C's Avatar
    Lizard, Cornwall
    2,599
    Quote Originally Posted by rhys1210 View Post
    both the front and rear are open diffs AFAIK
    Alex S3 AMK
  28. #27
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    Quote Originally Posted by Alex C View Post
    So having 2 open diffs should mean all wheels can turn at different speeds?
    come to think of it you dont get well hop when cornering on the standard controller, so having full time 4 wheel drive shouldnt cause a problem.
  29. #28
    Colly's Avatar
    Jan 2012
    Isle of Man
    277
    Has anyone got any experience of the sqs controller?
  30. #29
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    Quote Originally Posted by Colly View Post
    I dont think you can use this on the S3 with out warning lights coming on. As it is designed for people putting haldexes in mk1 and 2 golfs really which wont have all the sensors we have.
    Taken from sqs website
    SQS Racing | Haldex Regulator
    Hydraulic controler for Haldex transmission unit used in VAG Mk4 cars.
    Simple and reliable solution for Racing and special build cars where is not used original CAN-Bus wiring.
  31. #30
    S3Zek's Avatar
    Sep 2011
    407
    I know someone who has made his own, its just a adjustable valve and some pipe work to the inside of the car from the heldex adjusting the pressure adjust the split.I think It's as easy as that and the kits only about 40ish quid I think (don't quote me on that), but like said if it was on the s3 then the dash would prob light up like a crimbo tree. Run something like Mbe like he dose and it wouldn't be a prob
    this is it in action 2010 NEW!! A K Bodycraft 1/4 mile 9.89 seconds @ 148.7 MPH VW Mk1 Golf Turbo GTi Spring Festival - YouTube
  32. #31
    S3Zek's Avatar
    Sep 2011
    407
    By the way I didn't read the last post lol
  33. #32
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    A little update, I have managed to get the circuit up and running. Here is a quick video of the motor that is inside the haldex controller. I am able to control the direction by turning the knob "not in the video". The coding still needs some fine tuning and need to iron out some issues.
    Also I have noticed the oil temp sensor is located in the return side of haldex controller. This means its not a good idea to run a 50/50 power split as the oil temp sensor will not see any oil and wont be able to read the oil temp. So I'm thinking a 55/45 power split is a better safer option.
    Video - http://s1253.photobucket.com/albums/...2-08-13002.mp4
  34. #33
    rhys1210's Avatar
    Oct 2011
    Fareham
    153
    your video is in a private album.
  35. #34
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Thanks bud,should be sorted now.
  36. #35
    Aug 2009
    Cheltenham
    335
    Good interesting project, just a thought......a relay to switch the stepper between Haldex and manual override at the mating connector would be good for those with a working haldex.
  37. #36
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Quote Originally Posted by Barks View Post
    My set up is going to use the motor inside the haldex unit and bypass the haldex circuit, so won't be able to have std and manual options.
    Little update, I have got the motor moving the pin inside the haldex housing now. Have smoothed out the movement but still needs some fine tuning.
    Picture of the haldex unit that mates up to the diff
    and some very boring videos of the pin moving as I turn the control knob. Feel free to waste a minute or two of your life.
    http://s1253.photobucket.com/albums/...ipnomusic2.mp4 - with background music
    http://s1253.photobucket.com/albums/...ipnomusic1.mp4 - no music
  38. #37
    RIP S3dave
    May 2004
    nr Glos
    7,161
    exsqueaze me?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  39. #38
    Oct 2013
    Any update on this?
  1. Replies: 0
    Last Post: 22nd December 2011, 22:41
  2. For any wheels experts out there please!...
    By Audime in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st August 2009, 00:11
  3. General A3 Questions for you experts
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 21:48
  4. Feeler for Haldex controller Group Buy
    By simch in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2007, 14:05
  5. Few questions for the experts
    By imported_m20str in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th March 2006, 18:34
