Volks AutosChris Nott
Results 1 to 27 of 27
Like Tree1Likes
  • 1 Post By jezzy
Thread: s3 haldex 4x4 problem help please
    Apr 2012
    93
    hi all my 1999 s3 is only 2 wheel drive, I've checked for earth strap broken, but mine is a preface lift and the earth cable is not fitted nor is there a fuse for the haldex, I got a cheap vag-com and got fault code 00526 brake light switch, I cleared the fault and it has not come back, but my car is still 2 wheel drive, would a faulty brake light switch stop my haldex 4 wheel drive working ?, and if the brake light switch is faulty why do my brake lights still work? and why aint the fault come back,. Please help, thanks in advance ..
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,292
    Search previous posts on haldex issues, there is a complete thread on problems and resolutions . However it will have an earth cable and separate fuse somewhere along the line for the haldex controller to work surely......?
    Have a good look around on here in previous threads and I'm sure you will find the answer you require my friend.
    Cheers , Sean
    S3Zek's Avatar
    Sep 2011
    407
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Quote Originally Posted by S3Zek View Post
    No Zek, my 99 S3's Haldex is not fused either, has to be disconnected at the diff for a RR run!
    Anyways, to answer the op's question, either your Haldex controller is faulty or the wires going to it is corroded.
    You've got to have a laugh!
    Apr 2012
    93
    HI there aint an earth strap on pre facelifts nor fuse, vag com says its a brake light switch.
    Apr 2012
    93
    hi preface lifts dont have an earth strap or fuse, ive read loads of threads m8, im no futher foward , thankds
    Quote Originally Posted by s33nyboy12 View Post
    Cheers , Sean
    Apr 2012
    93
    hi m8 thanks for reaply, yes mine is a 1999 preface life, no earth or fuse,the wires going to it are fine, vag-com got fault code for brake light switch, ive reset and fault has not come back but still 2wheel drive. thanks
    Quote Originally Posted by jojo View Post
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,533
    Check your controller.. mines pre facelift but has a fuse coz its speshull but its your controller that'll be the problem or wires. Is your abs light on? tried cycling the pump also?
    Erf
    Oct 2006
    Kingston
    232
    could be either the controller as others have said...or could be the actual haldex clutch which would mean a replacement rear diff...or could be the pre charge pump.
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Apr 2012
    93
    HI GOPS thanks for reapling, you say check the controller, wot do you mean ?, no abs light on in dash and the abs pump hase bin recyled, many thanks
    Quote Originally Posted by Gops View Post
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,533
    Next on the left side near where the prop meets the diff is the haldex controller which controls the 4wd. That unit might be knackered. Check the wiring, and cycle the haldex pump on vagcom to see if that's working.
    Apr 2012
    93
    HI GOPS, thanks for taking the time to help me, ive only got a cheap ebay vag-com cabel, can i cycle the haldex pump with it ? thanks again..
    Oct 2011
    733
    there is a little shield on the rear diff at the back end, this houses a wiring connector to the haldex.
    unbolt the shield and unclip the connector if its corroded inside clean it up.
    if its full of oil your pre charge pump is gone.
    if you press the brake it disengages your haldex.
    so your brake switch sensor could be gone
    Apr 2012
    93
    Hi jezzy thanks for reaply, brake sensor or brake switch ? I got a fault code saying brake light switch. But cleared it and it ain't come back, thanks again.
    Quote Originally Posted by jezzy View Post
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,292
    Quote Originally Posted by HOTTIGGER View Post
    Yeh sorry mate it's jus I've seen 3 pre facelift with them like GOPs said.
    And change brake switch 1st , might be a cheap fix
    Cheers, Sean
    Oct 2011
    733
    as above
    if the code has cleared. see if your haldex is now working.
    no wheel spin
    Apr 2012
    93
    hi s33nyboy thanks for reaply, brake light switch ? or brake switch? or brake switch sensor like jezzy just said in thread ? i hade a fault code saying brake light switch. thanks again m8.
    Cheers, Sean
    Apr 2012
    93
    hi again jezzy, yes code has cleared and not come back, and is defo only 2wheel drive, i checked on the wet slippy roads not long ago, i cleared the fault code took it for a drive and scanned it again, no fault code, i dint change the brake light switch, i just cleared it thinking if it was faulty it wood pop back up as a fault code again, is this the case ? thanks again martin
    as above
    no wheel spin
    Oct 2011
    733
    No 4wd drive and no code.
    if your car is not slammed to the ground you will be able to undo the little shield and check the connector on the rear diff without jacking up the rear(the connector is on the rear diff not the haldex)
    Dosent take that long to check it and it will give you a better idea of your issue.
    Mine was the pump. oil in the connector. others was corroded wires.
    sometimes a oil and filter change on your haldex system will bring back 4wd.
    i would check the connector first. and keep an eye on your fault codes.
    keep us updated
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    When was the last time your Haldex was serviced?
    Apr 2012
    93
    hi jezzy, ive found 1 end of the connector under a heat shield by the back bumper, is that the heat shield i need to remove ? or the heat shield above the rear axel and diff ?, am i right in thinking that the brake light switch is not faulty as the fault code aint come back? or is it still faulty and ive just hide the fault when i cleared it ? , thanks again martin.
    keep us updated
    Oct 2011
    733
    The heat shield (more of a brackett than heat shield sorry)is tiny a couple of inches across and is on the rear diff.
    When you find the connector it joins the wires together in a block, so when it comes apart, pins one side and holes for the pins on the other.
    im not sure on the code (brake) if it does not come back you may you have moved it and is now working?
    HOTTIGGER likes this.
    Oct 2011
    733
    here is the connector in question
    Haldex not working? No communication etc? Look inside
    Apr 2012
    93
    thanks for all the help m8, nice 1 thanks again.
    Erf
    Oct 2006
    Kingston
    232
    Has anyone made any progress here?? I've recently changed my haldex oil and filter again and now the pre charge pump (used unit). Still no FU&KING JOY
    Surely this is an electric fault? Haldex kicks in, but doesn't disengage. Take out the fuse and voila. Haldex disengages.
    I still have to get my front right speed sensor as that is throwing an intermittent fault despite me changing it
    I've spent so much on getting this car fixed, I just want my haldex to work
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by Erf View Post
    Sounds like the speed sensor fault might not be helping... if its detecting 'wheelspin' (could be confusing the signal if there is a fault with the sensor or wiring to the sensor) then this could be tricking the haldex into locking on and staying on as it thinks it is in perpetual wheelspin...
    I would be looking at sorting the speed sensor fault out first before trying to find the haldex one as the systems are closely linked... you may find fixing the speed sensor issue cures the haldex one..
    <tuffty/>
  28. #27
    Oct 2011
    733
    if not the speed sensor (try cleaning the sensor)
    your haldex unit could be gone.
    Some members might have one lying around spare.
    couldnt hurt to ask
  1. AUDI A4 1998 Warning light problem? Help please!
    By jakeriddler in forum General Technical / How To
    Last Post: 22nd July 2008, 09:35
  2. Car Starting problems - Help please
    By max10 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2007, 10:05
  3. A3 problems, help please!
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2007, 13:13
  4. Replies: 1
    Last Post: 10th May 2006, 01:19
  5. A few problems, Help please
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2005, 22:13
