    Apr 2012
    16
    How do you remove the door blades and rear blades?
    Is it the 2screws on the inside of the door(one at each end) and the do you slide the blade off.....and the rear ones,are the two screws under the car aswell?? Help as I have to take some off 2mora at a breakers yard because myne are coming lose...cheers
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    Not sure if the S3 is the same, but on the S4 the blades are in two parts.
    The top painted cover just sort of pulls off, give it a tug at the bottom and it unclips.
    The back piece then slides along the door and unclips from the plastic things, once youve undone the screw.
    If you have an A3, with the rubberised trims instead, then theres no top cover to unclip, you just slide it sideways.
    TD5 Land Rover Defender build
    Apr 2012
    16
    Yea cheers mate.....yea I think you just undo screws on inside door and then just slide it off the clips.....can you also remove the s3 badge from the front grill or is it part of the grill?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Quote Originally Posted by Danny22 View Post
    4 screws mate, 2 you can see and 2 in the door, you need to remove 2 small rubber bungs to get to them.
    S3 door blade removal guide with pictures.
  1. How do you remove the rear wiper blade
    By gizmo666 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2011, 09:41
  2. How do you remove the rear bumper?
    By ru4shaw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 10:52
  3. How do I remove the light switch and...
    By JeffY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2009, 20:30
  4. How do you remove the facia around the HU and heaters?
    By bouncer--daz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2008, 19:21
  5. How do you remove the lower skirt trim?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2004, 19:50
