Badger5Volks Autos
    deana4's Avatar
    Jan 2011
    county durham
    29
    A3 1.8t running problems
    Searched through other threads but don't seem to find any answers so I'll start my own thread
    Ok so I have a problem with the running on my 1.8t. Standing still and rev in hard it borks now this also effects it when driving as it sometimes has power then other times it doesn't. I have put a forge split-r valve on as it runs better with this on(although not perfect) and I think it's because you get less boost with these valves on. If the standard one is put on it runs bad sounds like its on 3 pots. I did purchase a new one thinking that's what it was but still the same with a brand new one on.
    scanned the car and get pressure drop between turbo and throttle
    All help is much appreciated
    Dean
    Nick090884's Avatar
    Mar 2012
    rochester
    201
    Hi ya mate with the above fault you have given i had the same and it was the dv new bosch one sorted mine right out . wouldnt suprise me if your spliter r was the cause of that . alot of guys have said on here quiet a few times that our ECU's dont like them and our engines are closed loop which requires a recircualating valve etc OEM bosch 007 008 so on.Tuffty told me to check that first. Im nowhere near the level as some guy's on there just learn alot from the forum reading threads.
    Hope this help's
    deana4's Avatar
    Jan 2011
    county durham
    29
    Quote Originally Posted by Nick090884 View Post
    Hope this help's
    Thats what I thought but I have tried a brand new one not oem one but still the same problem. When the car gets up to temperature it's a lot worse
  1. A3 1.8T - Cold running problems
    By jiffi77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 16:00
  2. Cold running problems
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2006, 11:54
  3. lean running problem
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th November 2004, 01:39
  4. MAF / Airflow / Running problems
    By SimonA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2004, 17:45
  5. running problems
    By hendyc04 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2004, 23:26
