EM TuningMonster Motorsport
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By jamie408
Thread: S3 Drive shaft drone?
    Dec 2008
    Essex
    My S3 has been making this weird drone noise at around 15-20mph for a little while now. It sounds like a wheel bearing but I've had them checked and they are fine apparently. I notice it more as I'm slowing down to stop, It does it without the breaks applied so I've ruled them out. But recently It's doing it at normal road speeds, mainly at 60-65mph I notice it alot. As the wheel bearings are apparently ok the only thing I can think of is a drive shaft maybe, as I know the gaiter is split on the n/s and could well be quite dry by now? Could a drive shaft make this drone noise? Starting to annoy me now and I really want to get it sorted. The noise is defo from the front end I think, so I've ruled a noisy rear diff out as well.
    Any help would be much appreciated, thanks.
    jamie408's Avatar
    Aug 2011
    stoke on trent
    29
    Could be a bearing in the gearbox. When doin 60-65 push the clutch in see if it disappears. Also when when feathering the throttle does it change sound. Is yes then is say its a bearing in the box.
    Colly likes this.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,972
    Checked your tyres? I had a moaning from mine which I was convinced was a rear wheel bearing. Had it changed and it didn't improve, it turned out to be a dodgy rear tyre, we found it by swapping the wheels around on the car and following the noise....
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Dec 2008
    Essex
    Cheers boys, it makes no difference in/out of gear. And I fell down a pothole a little while ago and bent a wheel which I've had repaired, and had a new tyre put on the same time. But swapped the front and the rears but still no change. It could well be a tyre thinking about it, I did originally think that but its only recently started doing it at higher speeds. Just want to rule this drive shaft out really, I've never known one to whine/wurr?
    Dec 2008
    Essex
    Just been out in it again, and get a slight vibration thru the car/pedals as well as the drone. Did your tyre do the same Dave?
    Colly's Avatar
    The Tangerine Machine
    Jan 2012
    Isle of Man
    277
    Quote Originally Posted by jamie408 View Post
    surely even if the clutch was in the gearbox bearing sould drone as its still turning?
    Sold 03 S3 Audi Exclusive Papaya Orange,
    New Car 05 Evo VIII FQ 340 MR 415bhp 400ftlbs
    jamie408's Avatar
    Aug 2011
    stoke on trent
    29
    Quote Originally Posted by Colly View Post
    pushing the clutch takes pressure off the box from the engine. foot down it whines/ foot off it whines. if u get me my zaf is doin the same atm.
  1. S4 Prop/Drive Shaft?
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2006, 16:35
  2. Drive Shafts...
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2005, 23:57
  3. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
  4. vacuum pump / drive shaft
    By ajmackie in forum General Technical / How To
    Last Post: 9th October 2004, 20:44
  5. Vacuum source / drive shaft
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 03:30
